Robart gears for roo >
Old 08-19-2002 | 06:23 AM
Ragz's Avatar
Default Robart gears for roo
I need robart gears for the roo. The ones I am getting at the local HS are the 630's but there are only mains in it. What model do i need for the nose leg? The HS here say that Robart 640 105 degree nose leg may be suitable. The 630 are 90 degree mains. THey done have the special roo robart gear package available.
What is everyone else using?
Anurag
Old 08-19-2002 | 07:02 AM
My Feedback: (44)
Hi there;
It is nice to know that some people are flying Roos and may be turbines in India!!!
Any nose gear should work on the roo IF you choose it correctly. As you already know, Robarts makes a special gear for the Roo but it is really a standard product. If you have the mains, email Robarts and ask them to give you all the possible matching nose gear options.
Goos luck, I am on my Fourth Roo with Robart gears!!!
Old 08-19-2002 | 10:26 AM
The 105 degree rotation nose unit will work just fine.
Old 08-19-2002 | 12:03 PM
Ragz's Avatar
are the robarts an ABSOLUTE MUST???? I already have SA's with WABO struts (german brand)...bought them straight from F/C with the roo...i will get robarts only if these are a sure shot failure!!!...Any comments?
Anurag
Old 08-19-2002 | 12:55 PM
Anurag,
I use the SA's on my Roo, 3/16" wire struts.
I have to 'tweek' them back into position every few flights, but otherwise they work fine.
One good thing about them, in a hard landing they bend instead of breaking the mounts. Kind of like a fuse in the landing gear.
152 flights on them now.
Old 08-19-2002 | 01:02 PM
lov2flyrc's Avatar
My Feedback: (24)
Hey Anurag,
Glad to see your getting closer to flying your roo....I'm using the robart mains with a springair nose gear. No problem there! I prefer the springairs over the robart for the nose since it is firewall mount. Any heavy nosegear will do....
Regards,
Todd
Old 08-19-2002 | 01:26 PM
rcjetsaok's Avatar
My Feedback: (7)
Default Roo gear
Call Don Kanak at www.planesplus.com He has a complete gear set for the Roo with B.V.wheels and brakes.Works great!!!!
Good luck,
Dan M.
Old 08-19-2002 | 01:38 PM
cairoman's Avatar
Hi Anurag,
Try Graupner's landing gear (Eurokit retracts and struts, Liebetrau brakes), specially made for the Kangaroo.
http://www.graupner.de
They come complete with wheels and brakes and both valves to operate them. They will twist bend, even brake the main body on hard landings, but all parts are available, cheap and easy to replace. Also, Motors and Rotors stock these and will dispatch them to you immediately if you are in a hurry, they also carry all their spares.
http://www.motorsandrotors.com
They are much cheaper than Robarts and will work just as fine. Believe me, save the Robarts for a better project.
BRG
Chris
