Reload this Page >
new Arf Boomerang 14lb thrust
Old 03-28-2005, 06:31 PM
  #326
wd40
My Feedback: (81)
Default RE: new Arf Boomerang 14lb thrust
some more pic.
ID:	250711   Click image for larger version
ID:	250712   Click image for larger version
ID:	250713   Click image for larger version
Old 03-28-2005, 06:34 PM
  #327
rcguy!
My Feedback: (69)
rcguy!'s Avatar
ORIGINAL: wd40
some more pic.
Very Nice!
Got any shots of the mains?
Dave Rigotti
Old 03-28-2005, 06:35 PM
  #328
wd40
My Feedback: (81)
more pic.
ID:	250716   Click image for larger version
ID:	250717   Click image for larger version
ID:	250718   Click image for larger version
ID:	250719   Click image for larger version
Old 03-28-2005, 06:40 PM
  #329
rcguy!
My Feedback: (69)
rcguy!'s Avatar
ORIGINAL: wd40
more pic.
Tell us about the brakes? Nicely done!
Dave Rigotti
Old 03-28-2005, 06:42 PM
  #330
wd40
My Feedback: (81)
Time to get back in the shop and paint the 2nd coat of BVM heat sheild to the top cover ,and under the bottom of the turbine bay.
Mike Grant
Old 03-28-2005, 06:51 PM
  #331
wd40
My Feedback: (81)
The brakes were in my junk pile of old jet parts one works great ,but the other is leaking air then you roll the wheel I now remember why thay were in the junk pile and if I can't get them fixed soon I will order some from Sierra Precision thay make the best brakes I have ever used.
Old 03-29-2005, 02:48 AM
  #332
john agnew
Mike
Looks like a very neat gear installation. I would now advise everyone to install FOD screening to the intakes. Both Sandor and myself have suffered damage to our turbines due to dust / grit ingestion due to suction from the intakes. Sandor's pictures show the way to do it.
Good luck with getting a turbine for your Intro.
John
Old 03-29-2005, 02:53 AM
  #333
digitech
My Feedback: (10)
digitech's Avatar
ORIGINAL: rorywquin
ORIGINAL: Sandor
ok got the fod screen(s) done
got 3 times more air then before
Sandor, two questions
1 Have the new intakes solved your FOD problem
2 Do you notice any difference in performance with the new intakes ?
I am probably going to do what you have done but would like to know the outcome before I cut.
Rory
1 yes
2 cooler running , less fuel , better performance
Old 03-29-2005, 03:48 AM
  #334
rorywquin
Sandor
Good news & thanks - I have my blade ready for surgery.
What did you use for the screen ? I have not seen that anywhere!
Regards
Rory
Old 03-29-2005, 03:57 AM
  #335
digitech
My Feedback: (10)
digitech's Avatar
ORIGINAL: rorywquin
Sandor
Regards
Rory
the stuff i use is indeed extremely fine mesh
it is almost like a dust filter
that is why you need more opening otherwise you will get problems in letting air thru
i got it once from a friend
Old 03-29-2005, 07:19 AM
  #336
rcguy!
My Feedback: (69)
rcguy!'s Avatar
ORIGINAL: rorywquin
ORIGINAL: Turbinac
19:- The rear holes in the booms, through which the bolts enter the booms, have been cut 3mm. low in some kits. It only takes a moment using a dremel or knife to relieve the hole 3mm. = 1/8" at the top. Do not damage the keyhole block behind the hole.
When I looked at mine, I found that the key hole blocks were screwed too far up at the factory, and this is why there was an alignment problem. My guess is they they just screw them in at the factory and don't set them to any particular depth. I just unscrewed them a couple of turns and they were all perfectly aligned with the outer holes.
On my kit the 4mm screws contacted the boom sides. Had nothing to do with the adjustment of the locking mechanism. Once I elongated them @ 3/16" then the screws would pass thru the boom side and into the large hole in the locking mechanism.
Dave Rigotti
Old 03-29-2005, 08:41 AM
  #337
rorywquin
Dave
I'm with the programme now - once I put everything onto the wing joiner tube and aling the incidence pins, I mighr have to modify the holes!!
Sandor
Were you previously flying with the fine mesh over the side intakes which, led to a reduced performance of your turbine or, did you add the new intakes and mesh at the same time.
I suppose what I am asking is, did you add the new intakes to reduce the volume of intake air at the sides or, did you add them because you had the very fine mesh over the side intakes.
Rory
Old 03-29-2005, 09:13 AM
  #338
digitech
My Feedback: (10)
digitech's Avatar
ORIGINAL: rorywquin
Sandor
Rory
no before i had them stock ,but as i said i also suffered fod damage they are so small that they create a huge vacuum cleaner effect.
and can clean your runway while taxing[]
by opening the other intakes it would not do this anymore
i added both the stock and
the extra large opening
and now all is ok for the finemesh filter.
Old 03-29-2005, 09:36 AM
  #339
rorywquin
Bedankt!!
I have found some tea strainers with quite a fine mesh and will modify mine like yours!
PS - I learned to fly at MFK Lenticularis in Lelystad!
Old 03-29-2005, 03:14 PM
  #340
Turbinac
Dave, did you note the central cut out for wd40's noseleg.
I got your PM. Don't think that's a good idea. Thank you for the thought.
Alan
Old 03-29-2005, 03:39 PM
  #341
rcguy!
My Feedback: (69)
rcguy!'s Avatar
ORIGINAL: Turbinac
Alan
Alan,
Yeah I did...I also noted he was using an oleo strut. Were these to be included with the Spring Airs in lieu of the wire strut?
Dave Rigotti
Old 03-29-2005, 03:44 PM
  #342
DocYates
My Feedback: (102)
The strut WD40 is using is the same as the one I used, an Oleo strut that is provided with the Reaper kit from Mick Reeves. It may be one available off the shelf, but I do not know that for a fact. He and I have communicated about this, that is why I know the answer. I too am using the same nosegear strut.
Tommy
Old 03-30-2005, 07:05 PM
  #343
rcguy!
My Feedback: (69)
rcguy!'s Avatar
ORIGINAL: Sandor
Sandor,
Below is MY FOD screen work.
The screen on the scoops is 50 by 50 mesh 304 stainless steel. It measures 4" long by 2 1/4" high with bends at 3/8" in from each end. I tack it in place with cyano and then apply a bead of 5 minute epoxy smearing it into the screen. The screen was purchased from mcmaster.com part #9230T628. Open area 52.6%
The hatch openings (2) were located between two bulkheads and measure 2 " high by 2 5/8" long. Locate 1/2"-3/4" from hatch bottom. The location shown in the pictures below is at 1". Go lower to avoid messing with the trim color scheme. I removed the stringer. The screen is 18 by 18 mesh 304 stainless steel and measures 3 3/8" long by 2 1/2" high. mcmaster part #9230T622. Open area 70.4%. The total "open area" now exceeds the "as supplied" area by over 10%.
I don't know if this will help eliminate the FOD you and John suffered, but it seems like a good idea to me.
Maybe Alan has some thoughts for us? I do notice on some pictures of Boomerangs that the scoops are located on the hatch.
Mcmaster.com has many more wire cloth meshes too. Average price is $4-$5USD per square foot.
Dave Rigotti
ID:	251630   Click image for larger version
ID:	251631   Click image for larger version
ID:	251632   Click image for larger version
Old 03-31-2005, 02:46 AM
  #344
digitech
My Feedback: (10)
digitech's Avatar
ORIGINAL: rcguy!
ORIGINAL: Sandor
Sandor,
Dave Rigotti
looks good
and yes it will help to avoid fod damage
cooler running
Old 03-31-2005, 02:54 AM
  #345
john agnew
Dave
Excellent piece of work. I will be copying that exactly. I think Alan should address this issue by either including some mesh in the kit and advising that FOD may be a problem depending on runway conditions or, alternatively, re-position the intakes on top of the fuselage as per the kit version for his next run of ARTF'S.
Would he like to tell us if anyone has suffered FOD damage previously with the kit version?
Incidentally I will be lodging a fee note for development work tomorrow!
John
Old 03-31-2005, 03:00 AM
  #346
digitech
My Feedback: (10)
digitech's Avatar
ORIGINAL: john agnew
Dave
John
well john i dont think it can,t be alan,s designing
it is just some have problems some dont.
this fod screen solution is a nice add on and maybe can be sold as a optional item
i am sure alan will make the kits even better in the next run
and to look here to see small problems makes the next one only better and better i hope
Old 03-31-2005, 03:02 AM
  #347
digitech
My Feedback: (10)
digitech's Avatar
also i have a new idea:
i was looking at gear sets
does anyone has a spring air 700 series? with bulkhead mounting?
i believe these have a big pickup for the oleo,s? about 10MM?
can anyone confirm? the size schould be the same as the 300 and the 100 series
these would be exelent for my oleo,s
i would just have to make a few apdaptors for it
Old 03-31-2005, 03:07 AM
  #348
john agnew
Sandor
I think the 700 Springairs come with an aluminium plug which you can use for the supplied 5mm wire legs or remove it for 10mm oleos.
John
Old 03-31-2005, 03:11 AM
  #349
digitech
My Feedback: (10)
digitech's Avatar
Sandor
John
typical my oleo,s accept only 6mm
but no problem i have a small lathe so i can make the new plugs
lets make a call somewhere so i can buy a few sets.
i have over 30 flights now on the boomerang perfect everytime.
best trainer i ever had
Old 03-31-2005, 03:22 AM
  #350
john agnew
Sandor
Very good to hear you are enjoying the Intro. it really is a great flyer. I will try to make my FOD screens today and fly again tomorrow.
Sometimes work has to get in the way of pleasure.
John
