new Arf Boomerang 14lb thrust
#1326
My Feedback: (10)
RE: new Arf Boomerang 14lb thrust
ORIGINAL: Scott Douglas
Well, here's another one! I just have some minor tweaking to do and it's bicycle-clip time
Regards
Scott
Regards
Scott
you wont belive what it will pick up in your fuselage , how clean it is it will find something to mess up your day....
#1327
TN
Thats Great Dany......do you happen to have some pictures....i would like to make this mod for mine ...have not had a problem but would like to know exactly how you fabricated it and where you actually placed it.....is this glued to the Canopy of the Intro Boomerang??
Be Safe my friend...
Regards,
Steve
Regards,
Steve
#1328
Regards
Scott
Regards
Scott
I've just finished mine, so can I borrow your bicycle-clips for a while
#1329
Thanks Steve,
Unfortunately I am not able to provide you with pictures of my actual set up due to prevailing situation in Lebanon. Meantime, please find a couple of pictures already posted on this thread which will guide you through this step. I had to do a couple of baffles (3mm hard balsa) before i had one that I was happy with. Baffle is glued with 30 minutes epoxy and milled fiberglass to the former on the canopy (half way over turbine position).
Check out the pictures below. (for your guidance drawing of baffle is not accurate), but you can use given dimensions for a start and you can fine tune from there.
Finally, have applied two coats of BVM heatshield paint to protect the whole area including baffle.
Regards. Dany
Regards. Dany
#1330
Location: Hamilton, Scotland & La Roche Bernard, France
Hi Mike,
Not this weekend I'm afraid, I moved house recently so even getting a small chance to work on it's been a miracle. After a few troubles aligning the booms/dowels (I know you had fun too) I've got some a little soldering to do, secure the batteries and try to strenghten the noseleg, it seems very weak. [:@]
Still, on the plus side my new hanger's almost ready and I can get my F16 and F18 brought over now. I'm off on holiday soon as well so.. do I fly it before and risk being in a bad mood for 2 weeks or leave it and look forward to it when I get back??
Regards
Scott
Regards
Scott
#1331
ORIGINAL: traxxas
...why is everything so green and springlike up where you are..?...this was taken last week..our Lawns are all brown and cracked..[:-]
#1333
Mine was maidened this afternoon. Managed only one flight as the wind direction changed and our alternative runway is a bit shorter and I wasn't sure of the model yet.
But, the flight went reasonably ok. Took off with flaps extended, probably too much flap and not enough elevator compensating for the flaps, took about two circuits to remember about the flaps (only model I have that has them), Once I'd realised that and raised the flap, the model was trimmed out and flew quite well.
I'd set the timer for three minutes, then it was time to try some approaches. No sweat though, it was down on the first approach, a really easy to land model. It was coming in a bit quick for a start, but dropping back to idle and lowering the flap completely fair dragged off the speed and it was effortless.
Hopefully I'll get another chance tomorrow. Never tried the retracts up, didn't want to add another issue on the first flight. But I have to say that those Digitech Oleo Struts made the grass landing feel like tarmac.
Thanks for all the advice I've received on the forum.
Brilliant model
Brilliant model
#1334
MD, UNITED KINGDOM
ORIGINAL: Theyardarm
Carbon fibre wing tube stuck!!!!!!!!!!! Any ideas????????????
The cabon fibre wing tube on my Intro was a very tight fit and I made the mistake of lightly tapping it in - guess what - I cant budge it now - no chance of getting it out - any bright ideas?????
Have you tried leaving the model out in the sun. I was rigging mine the other day and the normally tight tube was real sloppy
Its worth a go
#1335
ORIGINAL: himagain
Its worth a go
[/quote]
..Did your oracover go at all wrinkley in the sun by any chance...Cant say i have had any trouble with sloppy tubes...i guess time will tell..
#1336
TN
Thanks David,
Did you trace from Alans drawing and is this just balsa??? what type of wood did you use for this...Looks like you have a nice fit in Canopy..
Regards,
Steve
Regards,
Steve
#1337
Steve
I recreated the template on graph paper from the photo on this thread. To be honest it would be just as easy to get some thin card and create the shape by trial and error. It was oversized for my engine set up, so I had to carve it to get the correct clearance once installed (just a case of trying the hatch for fit and looking down the exhaust end, gradually removing material until I was happy).
My baffle is made from liteply, and is fuel proofed where not painted with heat resistant paint.
David
David
#1338
TN
Thanks for the info David !!...I think the trial and error method with a thin type of paper or cardboard will suffice...Thanks again..
Steve
Steve
#1339
My Feedback: (8)
Started building my BB today. This is a great kit. It shows you dont have to give Bob $4000 to get a good kit and good flying airplane.
Is everyone using the supplied hinges without any problem. What servos? I am planning on using Futaba 3050s which are 92 OZ on 6V.
Has anyone put a P70 in the BB. Looks like a tight fit.
Gary
Gary
#1340
gary,
you will like the BB very much.....i liked the 1st one so much i got a 2nd kit to keep on hand as a spare.....mine uses a P-60 for power and it's perfect.....i used the spring-air retract package that's an option with the kit and they work great.....i also used BVM wheels and brakes on mine.....do yourself a favor and get the Mueller fuel tank for it.....it's an extra 25 oz. of fuel and it's custom molded to fit in the tank compartment.....i also used the supplied hinges and they work fine.....mine is geared up with all futaba servos.....i use 9202's on the elevator and ailerons, everything else uses std futaba servos.....balance it right on the center of the carbon wing tube.....that position works great for me.....got questions ?....PM or email me anytime......the BB is a great model.....
Richard
Richard
#1342
2nd tank down on this page:
http://www.angelfire.com/wi/jettech/page2.html
ORIGINAL: frothingslosh
Anyone have a link to the Mueller fuel tanks, specifically the one for the BB???
Frothingslosh
Frothingslosh
#1343
I just got my jet tech tank, ordered it from Dreamworks, good delivery time and follow-up.
The tank is worth the investment, and honestly I would have thought it would be heavy, turns out to be much lighter then the dubro 50 oz tank.
#1344
Im just about to order my intro from alan,
Ive searched the thread, but can find little info on rail mounted front U/C. ( Im retiring a stingray so happen to have all the kit including spring air 30-1/2?s)
Is there enough room up front for a standard servo, or would some cunning pull-pull wires be required?
#1345
Hi Gang
Alas, I must report the untimely demise of my Intro [&o]
For some reason, as yet unknown, the model went into fail safe on a 'dirty pass' before landing and nosed in on the rwy from about 60ft. I doubt I will ever set the fail safe system again!!
The engine has gone for repair and doesn't seem to be too badly damaged. My 9x will be going away for a service to see if the problem was caused from it. I got most of the equipment out of the model and the wings are relatively untouched (any one needs them, PM me). But I did lose the SA 101HD nose unit (anyone has one PM me!)
The Intro is a fantastic model and I'll have one again in the future I'm sure. Got other irons in the fire for now though!
Chris
Chris
#1346
Reply to bidrseed2.
The Intro(called Baby Boomerang now) uses a bulkhead (firewall) mounted nose retract. But it's easy to use a rail mounted retract by mounting it on a 19 size glo motor nylon or plastic motor mount bolted to the bulkhead. The servo mount can be turned to sideways across the retract compartment to accommodate pull-pull wire linkage.
Alan
Alan
#1347
Thanks turbinac, That will save me £50 by avoiding having to buy a new one.
It had looked from a few of the photos that the servo mount was fixed, and that there wasnt room at the front for the servo. Its good to know it will work with my retract.
#1349
Just need to say that having called Alan a few time. the customer service is A++++++++++++++. even if it was not the model certainly is, Best flying model I have flown. If i had to leave one of my jets behind it would be the hawk or the kangaroo ,never the Boomerang.
#1350
OH
Hi everyone. Hope there are still a few guys watching this thread!!!
I'm getting ready to mount my new JetCat P70 in my new (first jet) Baby Boomerang. I find that I'm going to have to add some spacers to the wooden fuse. motor mounts to get the engine to clear the lower bulkheads. Am wondering what is the min. space I need to allow between the engine and lower bulkheads?
Also, I'll need to trim the outer edges of the engine mounts a little to get them to fit within the fuse., and cut some off the front of the mounts to get the engine as far forward as possible. Is this the way everyone else is doing it with the P70???
Thanks in advance for your time.
