 UP-6 help!?!?!? >
UP-6 help!?!?!?
UP-6 help!?!?!?
Old 01-10-2005 | 12:13 AM
KFalcon's Avatar
My Feedback: (18)
Default UP-6 help!?!?!?
I have a UP-6 valve that is acting up. It will put air to the brakes but when I try to release the air from the brakes the air continues to release air from the tank through the port on the valve. Any suggestions?
Old 01-10-2005 | 12:30 AM
Default RE: UP-6 help!?!?!?
Hi Ken
Does the stem come all the way back or only part way?
Ed
ORIGINAL: KFalcon
Old 01-10-2005 | 12:40 AM
P38J's Avatar
My Feedback: (14)
Make sure the actuator arm is being released all the way and double check you connections to the valve are correct.
Old 01-10-2005 | 12:44 AM
mr_matt's Avatar
My Feedback: (10)
Also I assume you have it hooked to a brake cause the way I remember it will not close without the backpressure of the brake.
Old 01-10-2005 | 03:20 AM
KFalcon's Avatar
My Feedback: (18)
Thank you all for the input. The lines weren't connected to the brakes as I was just trying to set up the gear door sequencer and check gear operations. Once they were hooked to the brakes they worked like a charm. Thank you all.
