Kangaroo Hinging >
Kangaroo Hinging
Kangaroo Hinging
Old 09-03-2002 | 11:01 AM
Default Kangaroo Hinging
I am looking for advice on the best way to hinge a kangaroo. This is the older (foam wing) kit. The intructions say to use the top hinging method using robart hinges. is this a satisfactory way of hinging. Is is strong enough to glue the hinges to the balsa facing, and the foam cores of the flying surfaces.
thanks
Don
Old 09-03-2002 | 11:23 AM
i rather use robart hinge points at the center of the surface and i cap leading edge of aileron with 1/4 balsa sheet ant bevel, then i insert the hinge points with 45 min epoxy.works perfectly.
all the best/fred
Old 09-03-2002 | 11:28 AM
I used their recommended method.
Use plenty of epoxy, mine has 164 flights on it and they're still tight.
