BVM Balsa Bandit
Pdman
My super bandit weighs 17lbs dry with a manual start Wren 54 Mk3. Turbine weighs 2 1/2 lbs including pump, ecu, and pump battery, ecu runs off receiver battery ,2700 mah nimh 6volt. no bypass, homemade tanks, springairs with wire legs/intairco wheels / brakes, no gear doors.
This is a simplified bandit for grass strip operations.
John Agnew
John Agnew
