Can a tailpipe be made of copper?
I suspect that the strength and modulus will be significantly less than stainless. That means, for it to be as strong (resistant to bending and resistant to collapse, compressive stability), it will need to be thicker than a stainless pipe. Been using .008 stainless on Isobar pipes for years. You can get them cherry red and blue all over and they are just fine with no collapsing.
Sean,
Where do you get your .008 stainless steel sheets. McMAster only carries 12 " wide. I need atleast 18" wide for the outter pipe.
TIA,
Eddie Lozano
TIA,
Eddie Lozano
My Feedback: (31)
KY
Sean, i worked with copper for many years in my fathers business. The copper will radiate the heat and become cherry red. As for melting im not sure but im not sure i would like it. Russ
My Feedback: (60)
Eddie,
The only one I know of is 12", Eddie Weeks told me I could make a couple of pipes out of this??? I'll have it on hand here in a couple of days and will report how it turns out in my isobar build thread later on.
Part Number 90415K172 $118.00 Each
Shape
Sheets and Bars
Sheets and Bars Type
Coils
Thickness
.008"
Thickness Tolerance
±.0005"
Length
7'
Length Tolerance
±1"
Width
12"
Material
Type 301 Spring Tempered Stainless Steel
Finish/Coating
Unpolished (Mill)
Tolerance
Standard
System of Measurement
Inch
Material Certification
Without Material Certification
Shape
Sheets and Bars
Coils
Thickness
.008"
Thickness Tolerance
±.0005"
Length
7'
Length Tolerance
±1"
Width
12"
Material
Finish/Coating
Unpolished (Mill)
Tolerance
Standard
Inch
