Modifying ARFs
My Feedback: (31)
KY
Has anyone done or even givin thought to modifiying some of the larger ARFs out there now such as the skymaster F-18, F-15 or Composite ARF Euro, to accept twin 12 to 14 lb engines vs the one large engine ?
I know the question will be WHY?, for me it is the neatness factor of acutal twins and the avialiablity of the smaller motors to me. Russ
My Feedback: (31)
KY
I was thinking of taking the Skymaster for example, Hogging out the formers just a little bit and installing an overlay that will enable me to mount the 2 engines. The tail pipes should not be an issue. I think the sound would be awesome. Russ
My Feedback: (8)
ORIGINAL: J Campbell
If you building it for US use you had best include By passes .. so that it will conform to AMA rules BTW a twin sound just like a single, I cannot detect any diference ( that is on a Me 262)
Semper Fi
joe
My Feedback: (29)
If a twin turbine powered model does not have bypasses in it, then it will not be allowed to fly at some AMA events. This is going to be the decision of the event CD and some CDs have already stated that bypasses are the only effective means of partitioning.
Why take a chance?
Why take a chance?
My Feedback: (24)
ORIGINAL: grbaker
Why take a chance?
Why take a chance?
My Feedback: (31)
KY
Before long we will have to go through an FBI background check and obtain a licence to buy and fly a jet. AMA, SUCKS!!!!!!!!!!!!!!!!!!!!!! Russ[>:]
My Feedback: (29)
510-A Safety Code for Model Aircraft Gas Turbines
#5 under Airframe Requirements: Enclosed multiple engines must be segregated in separate pods or partitions where exhaust gases cannot mix causing cross-ignition.
http://www.rcuniverse.com/forum/m_18..._3/key_/tm.htm
If you want an event CD to have a "legal reason" to ban your twin JetJoe powered ARF to fly, then just leave the bypasses out.
