 I'm Wondering. >
I'm Wondering.
I'm Wondering.
Old 04-19-2005 | 05:52 PM
Default I'm Wondering.
I'm Just Curious of how do you guys start up these jet engines? They're so cool to listen to.
Old 04-19-2005 | 06:52 PM
Countryboy's Avatar
My Feedback: (25)
Default RE: I'm Wondering.
ORIGINAL: Philng
Hand crank....just like the old Model T used. When your arms give out, the next man takes over. The kick back is not quite as extreme on the turbines as it was with the Model T though.
Old 04-19-2005 | 07:08 PM
oh, so you just spin the shaft until the engine turns on?
Old 04-19-2005 | 07:17 PM
grbaker's Avatar
My Feedback: (29)
Some are spun up using compressed air from a scuba tank and others are spun up by an electric motor mounted on the front of the turbine.
Old 04-19-2005 | 08:01 PM
oh ok, that would be hard trying to spin it up that fast using your hands. oh, is it possible to add an afterburner to one?
Old 04-19-2005 | 08:26 PM
grbaker's Avatar
My Feedback: (29)
It is against current AMA rules to use an afterburner. There is one production turbine in Europe that has an afterburner on it. Fuel consumption on turbines is pretty high and an afterburner would make it much worse. Most jet models now days are near 1 to 1 thrust to weight ratio or better anyway, so afterburners really are not needed. Most models could not handle the extra heat, either.
Old 04-19-2005 | 08:40 PM
ok, I don't think i'll be flying a jet anytime soon. I'm just starting with RC and curious about those things. Thanks
Old 04-20-2005 | 01:00 AM
Banned
My Feedback: (119)
See that bullet shaped thing on the front of autostart engines? That takes a shotgun cartridge minus the buckshot. You whack on the front of the housing with a hammer, the firing pin sets off the starter cartridge, and the blast from the cartridge spins up the engine. That's how we do it in Brooklyn, those dopes down in Kentucky want to hand-crank, it's no sweat offa MY back.
Old 04-20-2005 | 06:08 AM
Countryboy's Avatar
My Feedback: (25)
ORIGINAL: EASYTIGER
Way too go ET.... lead your fellow New Yorker astray!!! Shotgun shell you say, well here's a thought.... don't hold your farts in, they will travel up your spine where they reach the brain, and that is where shi*ty ideas come from. Although my reply too the inquiring mind of Philng was perhaps in poor taste, it was all in good fun... sorry Philng. The only thing is ET, unlike your shotgun shell method, my recommendation does hold a wee bit of validity.
1. Commence vigorous hand cranking, 2 operators.
2. At IGNITE speed, tachometer indicating 450 to 550 rpm and fuel pressure gage reading 550 lb/sq. in. minimum, open fuel control valve to on position.
3. Continue vigorous cranking to STOP CRANKING speed, 1200 to 1300 rpm indicated on tachometer, from which point the engine will accelerate normally to rated speed.
With engine stabilized at rated speed, oil pressure should be 20 lb/sq. in. minimum and exhaust temperature normal operating range is 600 to 950 deg. F, (315 - 510 deg. C).
Normal running speed is 4430 rpm, speed must not be allowed to fall below 3600 rpm and avoid running at speeds in excess of 4500 rpm.
Shut down sequence to stop engine, allow 2 to 3 minutes running at no load in order that engine may cool down, turn engine fuel control valve to off position.
Note that all tachometer speeds quoted are output shaft speeds, the turbine is actually turning at over 40,000 rpm. The spiral bevel gear in the gearbox is rotated at 9.1 to 1 by the bevel pinion mounted on the end of the turbine rotor shaft. A reversal of this speed reduction by hand cranking, together with the speed increase in the chain and sprocket linkage, allows the operator to crank the engine with an approx. 70 to 1 speed increase. The magneto operates continuously to fire the spark plug whilst cranking and stops when hand cranking is discontinued, the sprag clutch disconnects when the turbine speed exceeds the cranking speed.
Old 04-20-2005 | 07:38 AM
so all in all, it takes a lot of work to start one?
Old 04-20-2005 | 08:31 AM
Banned
My Feedback: (119)
ORIGINAL: Countryboy
ORIGINAL: EASYTIGER
I think you are konfused, that's not the starting procedure for a model turbine, that's the starting procedure for the old John Deere tractor that you drove to your high school junior prom.
Old 04-20-2005 | 09:03 AM
ORIGINAL: Philng
Before these two practical jokers lead you astray too far, you might be interested in this link which takes you to a typical manual of one of these turbines:
http://www.pstjets.com/download/J600...1%20public.pdf
Cheers,
Old 04-20-2005 | 10:55 AM
thats cool, thanks
Old 04-20-2005 | 11:16 AM
ORIGINAL: Philng
thats cool, thanks
N/P - Hope you enjoyed the information. As you can see operation of turbine engines is much more complicated then the general R/C type aircraft and take time to learn and properly operate. Your started in the right direction though and trying to learn as much as you can. Read a lot, ask questions and always go to the experienced fliers. They'll save you a lot of grief. Above all continue to build your time with R/C. Jet powered airplanes are not cheap and very expensive mistakes when not properly flown.
Cheers,
