Reload this Page >
JetJoe OWNERS thread
Old 01-31-2012, 05:10 PM
  #3376
Dr Honda
Dr Honda's Avatar
Default RE: JetJoe OWNERS thread
Your link is to your account. Post the link under "Share."
Old 01-31-2012, 05:20 PM
  #3377
idleup1
that is the link yes. I don't run a solenoid on the gas as it adds weight and I have had them stick .
Old 01-31-2012, 05:41 PM
  #3378
Dr Honda
Dr Honda's Avatar
ORIGINAL: idleup1
No it's not. (sorry) it's the video in your account. Not the public video.
Here's your video.
http://youtu.be/0Kz34qDvMTQ
Old 01-31-2012, 05:46 PM
  #3379
idleup1
sorry. been up since 4am
Old 02-01-2012, 01:59 PM
  #3380
menzapsi
Hi James
It look like you just run on gas. Test the pump on bench with a variable power supply. With 4,5V you get near full jet. The pump must start at 1,8V/0,8A. If it need more volt or more amps, loosen (in small step) the 2 screws of the pump. The pump have metal brushes that wear in contact with the rotor. On the pictures you can see my pump after 12 running hours. To fix the problem I have take complete cover of a NINCO NC-5 slot motor.
Jean
ID:	1722107   Click image for larger version
Old 02-01-2012, 02:41 PM
  #3381
idleup1
If you can['t get past 45,000 rpm you are probably not getting fuel. to test pump disconnect the fuel line at the motor and and attempt to prime the pump . I don't know what ecu you have to tell you how to do that. if you here the pump buzz and get no fuel check your solenoid. it should open in prime mode.. if that work then the ecu is no telling it to start pumping. spin motor and check that rpm registers. check thermocouple won't pump till 100+. if you over heat the ecu wiill not pump more fuel till temp drops under limit.
Old 02-02-2012, 02:38 PM
  #3382
jymster
My Feedback: (9)
jymster's Avatar
Thanks for your help guys. It is very odd, as I recently took the Junior over to Smithy's place and it ran fine with my pump, my gas bottle, my ECU, etc. I figure I must be doing something wrong in the start procedure. I have tested the pump in priming mode and it works fine. I have also tested the pump by removing the fuel line from the turbine and going through the startup procedure to see if the pump is kicking in at the correct rpm and temp settings, and it seems to be. I just can't figure it out. Maybe the pump is not working under the back pressure it is getting when it is hooked up to the turbine. It works fine with the fuel line runnning in free air, but when I hook it up to the turbine it seems to not be working. It is very strange. I am planning on going back to see Smithy to set it up in his workshop again to see if it is me, or if it is some component in my setup.
James.
Old 02-02-2012, 02:54 PM
  #3383
Dr Honda
Dr Honda's Avatar
Maybe your fuel needles are plugged.
Old 02-11-2012, 04:51 AM
  #3384
nipmuck2
My Feedback: (52)
Can someone post a photo of where the fuel and gas lines go on the JJ1400. I am new to JJ engines and confused on what side takes what line. There are 3 fittings and I am so confused?? I know it must be here somewhere (and I looked) but there are over 100 posts and I get caught up in some of them and forget what I came for .....LOL Any help would be appreciated.
Thank you,
Old 02-11-2012, 06:33 AM
  #3385
DaveJohansen
My Feedback: (8)
DaveJohansen's Avatar
ORIGINAL: nipmuck2
Thank you,
Fuel is the clear line..... Start gas is the orange
Old 02-11-2012, 06:39 AM
  #3386
Xairflyer
Xairflyer's Avatar
try this
  #3387
idleup1
Middle line is gas. tee goes to fuel. Restrictor in line to lube.
Old 02-11-2012, 09:53 AM
  #3388
nipmuck2
My Feedback: (52)
Xairflyer,
That's exactly what I was looking for.
Thank you very much!
Steve
Old 02-15-2012, 10:24 AM
  #3389
blakeketcham
My Feedback: (61)
Hello has anyone been able to order from jetjoe? The site is giving me problems and I don't know who is distributing in the USA. Thanks Blake K
Old 02-15-2012, 11:17 AM
  #3390
idleup1
Site is back up. yoo can email [email protected] order. no us distributer.
Old 02-28-2012, 01:57 AM
  #3391
chrigui
[link]http://www.6158.net/com/stks1/home.php[/link]http://www.6158.net/com/stks1/home.php
try here
Old 03-13-2012, 07:39 AM
  #3392
toolmaker7341
toolmaker7341's Avatar
Is there a thread showing how to rebuild a 1200-1400?
Old 03-13-2012, 08:31 AM
  #3393
idleup1
http://www.rcuniverse.com/forum/m_94...tm.htm#9458885
Old 03-13-2012, 10:00 AM
  #3394
toolmaker7341
Thanks for the link. I just bought 1 complete and 1 missing the case to learn rebuilding turbines. I'm sure I'll be asking the advise in the future.Anyone order parts from JetJoe lately? How do you pay?
Old 03-13-2012, 10:49 AM
  #3395
CRX Turbines
Hi Mike,
Paypal is the only way to go with Joe. I can not imagine there is anyway to go with this.
Andy
ORIGINAL: toolmaker7341
Old 04-01-2012, 10:25 AM
  #3396
sysiek
My Feedback: (176)
sysiek's Avatar
The jetjoe site do not works please help with where to fund some parts for jj 1400 thanks.
Old 04-01-2012, 11:35 AM
  #3397
knobby1
ORIGINAL: sysiek
Try this link:
Jet-Joe is now run by a new owner, Jason. So far he seems to be pretty easy to contact and talk to via email.
Cheers,
Smithy.
Old 04-01-2012, 11:50 AM
  #3398
sysiek
My Feedback: (176)
sysiek's Avatar
Hi I try this before only opens to half ways and stop, thanks I will try again .
Old 04-01-2012, 11:52 AM
  #3399
knobby1
ORIGINAL: sysiek
Just tried it myself two minutes ago, seems to work fine here..!!?? Possible problem with your ISP..?
Cheers,
Smithy.
Old 04-01-2012, 12:06 PM
  #3400
sysiek
My Feedback: (176)
sysiek's Avatar
I found from USA is http://www.6158.net/com/stks1/cp.php?nowmenuid=52330
