Byron F-16 C/G?
Byron F-16 C/G?
I need the center of gravity location for the Byron F-16. Preferably the dimension from the fan bulkhead face or from the wing spar etc. as I do not plan to use a ducted fan to power it. I am converting an old d/f model to a pusher prop-jet configuration like the Combot Models F-16.
Thanks in advance,
Rob
Wow! that did not take long............. I downloaded the Byron F-16 Manual and now have all the info I need. Guess we can close this thread.
Thanks to all!
Rob
Thanks in advance,
Rob
Thanks to all!
Rob
Byron F-16 C/G?
Sorry - can't give you a dimension - all I can say is that I balanced mine exactly on the glo-plug of the OS-91. Don't know if you can figure out where that would be since you are not using a DF motor.
I seem to remember there being a copy of the Byron F16 manual online somewhere - Ithink it was on the USRCJC web site. Go have a look there, and you might get your answer.
Gordon
Gordon
