 P70 in Roo mount >
P70 in Roo mount
P70 in Roo mount
Old 09-02-2005 | 11:44 AM
My Feedback: (8)
Default P70 in Roo mount
Does anybody have any suggestions for fitting a P70 in the Kangaroo mount. I am thinking cut and reform.
Jet cat does not have a mount for the P70.
Gary
Old 09-02-2005 | 12:23 PM
seanreit's Avatar
My Feedback: (60)
Default RE: P70 in Roo mount
Gary, do a search for kangaroo mount in the jets forum, any thread that username seanreit has responded in will give you a step by step on making a custom mount. Takes about an hour to make it and a few hours for it to cure up, but works incredibly well.
Good luck,
Sean
Old 09-02-2005 | 01:00 PM
erbroens's Avatar
I Think that Sean is talking about this thread:
http://www.rcuniverse.com/forum/m_12...tm.htm#1203416
I also recently made a P-80 mount for my roo: used the top side of the original factory mount and a strip of 2.5 mm aluminum. rounded it over a pvc pipe and used some washers between them to get the right grip.
Best regards, Enrique
Old 09-02-2005 | 03:45 PM
My Feedback: (24)
Gary, I used the P80 mount from JetCat, cut approx 3/4 inch away, and mended the seam with a piece of aluminum. 8 small nuts/bolts are holding the plate/seam together. Bob
