Tailpipe size
Hi Vin
Hmmm getting cold up this way now and I am taking a break from glueing and painting. I show.....3.5" diameter on the RAM 500 and the PST 600 should be about the same.
Oops
Maybe I misread the post? Vin did you want to know engine diameter? Then it is 3.5 " for the SimJet, RAM and PST. The exhaust tube on the other hand should be around 21 mm if used as a straight non tapered design. Tam probably has done the most testing here and his measurements are probably even more efficient. I think BVMs F86 pipe etc is roughly that diameter.
sorry boot that
sorry boot that
AHHHHH........I think its time to go to bed. Geeszzzz you'd think I did not know my metric from standard measurements!!!!! My elementary school teachers would be turning in their graves right now. Lets try this again.....at RAM in early 2001 a number of tests were done using different diameter exhaust ducts. The most efficient ( lowest temp for greatest thrust output ) was found to be about 2 1/4 - 2 1/2 inch diameter or......ready for this ( drum role please 55 - 60 mm )
O.K. I am done for the day....goodnite
Dean,
Now you just make me reallized Vin question go both way.
I read his subjet heading before his question.
But if I read his question first. My answer just like your.
If your a** getting freeze. Fire up those turbine heater.
Tam
Tam
