 Name this Jet >
Name this Jet
Name this Jet
Old 10-12-2005 | 04:45 PM
McclureMitch's Avatar
Default Name this Jet
What is this ?
ID:	338107   Click image for larger version
ID:	338108   Click image for larger version
ID:	338109   Click image for larger version
ID:	338110   Click image for larger version
ID:	338111   Click image for larger version
Old 10-12-2005 | 05:04 PM
Default RE: Name this Jet
Old 10-12-2005 | 05:07 PM
Fury
Old 10-12-2005 | 05:13 PM
uncljoe's Avatar
My Feedback: (8)
FJ 4 B "Fury" North American...... attached to FAGU 1956/57 scheme , different than the F86
Semper Fi
Old 10-12-2005 | 07:46 PM
erbroens's Avatar
It is a proof that sometimes is better to not change much the original idea....
Enrique
Old 10-13-2005 | 08:33 AM
This aircraft is NOT a Fury but it is an F-84 Thundersteak
I've got some cool books!!
Old 10-13-2005 | 08:51 AM
Nope sorry JETACE..it is a Fury as they said...the Thunderstreak had the tailplane half way up the rudder post....good try though
Reuben
Old 10-13-2005 | 08:53 AM
This can help
http://meltingpot.fortunecity.com/cl...ets/d-f84f.jpg
Reuben
Old 10-13-2005 | 09:00 AM
RBardin's Avatar
My Feedback: (27)
The FJ-4B was a ground attack version of the FJ-4, and was in fact built in larger numbers than the original FJ-4. It was similar in concept to the F-86H Sabre, although there was no direct relationship between the two aircraft other than their common ancestry.
The FJ-4B differed from the FJ-4 by being strengthened to take six underwing ordinance stations capable of carrying a total of up to 6000 pounds of fuel tanks, rockets, or bombs. It could carry up to four underwing drop tanks (2 150-gallon and/or 2 200 gallon tanks).
The FJ-4B was equipped with a set of flight spoilers situated just ahead of the trailing-edge flaps, which were used at low altitudes and high Mach numbers to improve the controllability.
The FJ-4B was also fitted with an additional pair of speed brakes underneath the fuselage near the tail. These brakes were linked to the main speed brakes on the fuselage sides just aft of the wing trailing edge and could be used to reduce speed during low-level bombing attacks. However, the primary purpose of these additional brakes was to reduce carrier landing speeds and to give the aircraft better go-around capabilities in case of a bolter. The brakes made it possible to use a higher engine RPM during landings, avoiding a regime in which the engine ran roughly. Just before landing, these additional brakes were automatically closed when the undercarriage was lowered to prevent the brakes from scraping on the deck during landings. All four of the speed brakes were activated by a single switch on the throttle lever.
Found the above info here: http://home.att.net/~jbaugher1/p86_24.html
Old 10-13-2005 | 09:29 AM
My Feedback: (12)
YOU ARE WRONG ! That is an FJ4B that is owned by Rich Sugden. I have over 100 hrs in that very airplane. I flew it as a member of VA-216. 1959-1961 You might note that I co-authored the article about the a/c with Joe Baugher.
Old 10-13-2005 | 09:49 AM
RBardin's Avatar
My Feedback: (27)
Hi Hal,
Nicely written article! Very informative, I enjoyed reading it.
I'm not huge into ordinance, but it was especially interesting to read about the Bullpups radio controlled guidance system - Looks like you and the other FJ-4B pilots were some of the first r/c jet pilots ever. And got to do it while flying a real one - now that's Cool stuff!
Rusty
Old 10-13-2005 | 09:52 AM
uncljoe's Avatar
My Feedback: (8)
Hi Hal
Where does Mr Rich Sugden hangar his beauty?
Semper Fi
Joe
Old 10-13-2005 | 10:02 AM
My Feedback: (12)
I got to fire only one Bullpup at NAS China Lake in 1961. Got a bullseye diving from 30,000'.
We had a computer with a controller that we used to practice with in the squadron. It was very similar to a present day computer game.
Old 10-14-2005 | 08:18 AM
HalH,You flew the real thing?? That is Sweet!![8D]
