Ram 750F info ??
My Feedback: (41)
MA
What info do I need to find out if they are in compliance with the AMA failsafe rules? I see that there are a few for sale here and need to know if they are worth purchasing or if they would be good paper weights? Thanks
My Feedback: (28)
TX
as far as I know, they would be in compliance already if the engine shuts down in failsafe mode which you can be programed from your radio.
If you want the 2 second mod, do a search, there are a few that post on here that can help you.
My 750F is in compliance with the 2 second AMA requirement. To make this happen, the ECU needs to be modified by Andy Low at Electrodynamics. He is the designer of the original RAM 750 ECU. Not to be confused with Bob Price, who designed and still services the ECU for the RAM 500 engines.
Hi,
The RAM 750F is no PAPERWEIGHT! One of the best RAM ever built i still fly mine and with carlos around will for many more years.
If you can find one for $1200 to $1500 snap it up
thanks
thanks
My Feedback: (7)
ON, CANADA
I have a 750 P which I sent to Bob Price and he updated the ECU to meet the current AMA fail safe requirements.
If you need the info send me a PM and I can dig up the info for you.
Good Luck
Ted
Good Luck
Ted
TX
I don't believe Andy from Electrodynamics is doing any more work on the ECUs. So if it isn't updated already I'm not sure who else will touch the older ECUs.
Other than that the 750's are good turbines. Thirsty little things though.
JR
JR
