Amt Data Terminal >
Amt Data Terminal
Amt Data Terminal
Old 11-14-2002 | 11:06 PM
My Feedback: (41)
Default Amt Data Terminal
HI. HOW DO YOU CHARGE THIS THING?? 15HOURS AT, 12 VOLTS ,OR 50MA FOR 15 HOURS???BIG DIFFERENCE HERE..WHAT CHARGER?? NONE OF MINE SEEM TO WORK ..THANKS RALPH
Old 11-14-2002 | 11:14 PM
Laura H's Avatar
If it is the same as the Amt Netherlands one you charge it using 12 volts......I had to leave mine on for more than 15 hours for it to be fully charged...
Old 11-15-2002 | 01:18 AM
yeahbaby's Avatar
My Feedback: (21)
Default EDT charging
Rapptor,
Mick is absolutely correct. just use the cables supplied and plug into your 12volt battery. leave it on overnight and walk away. I charged mine once and used it for nearly 2 years of off and on use. I would leave the country for 6 months at a time and didn't worry about charging when I returned. Maybe I got a super dooper battery pack with mine, not sure but no kidding I didn't charge mine once after the initial charge. I would surmise that with regular use you will have to charge periodically but I haven't experienced that yet.
sorry for the delay,
Buck
