 The McMaster List >
The McMaster List
The McMaster List
Old 12-22-2005 | 04:11 PM
Thud_Driver's Avatar
Default The McMaster List
This is a response to Seanreit's request for a McMaster-Carr list of items useable for jets. Since his post got a little sidetracked and I'm just now back in town, I started a new thread.
Cut and paste the part number for the item of interest from the attached text file into McMaster's search window to get to the catalogue page. Then you can look +/- a couple pages for items of a similar nature you might like better. I have bought and used most all the items on this list so can speak to most any of them. Prices on the list may or may not be current. Use their Bookmark system to find items again later.
McMaster invites small orders but they will charge actual cost for shipping, so be careful if you order something heavy, large or long. In California, we also pay sales tax, don't know about elsewhere. They do ship fast. I've gotten orders in less than 24 hrs, but I'm not all that far from them.
Post any additions you might have.
File Type: txt
Old 12-22-2005 | 07:13 PM
Edgar Perez's Avatar
My Feedback: (13)
Default RE: The McMaster List
Great list. Thanks
Old 12-23-2005 | 12:04 PM
Thanks, great list!
I work for an engineering company in Oslo, Norway, and we buy a lot, if not most of our production hardware and general shop needs from mc Master. Amazing store. We even get all our metric hardware from them, its cheaper and faster with a better selection than from across town here! Whenever we get a salesman from a local company at our door, we show him the mc Master catalog. They just end up speachless.....
- Thore
Old 12-23-2005 | 01:23 PM
FalconWings's Avatar
My Feedback: (57)
Thore, try also www.grainger.com
It is just as good, but also has higher end items.
Old 12-23-2005 | 01:56 PM
DanSavage's Avatar
ORIGINAL: Thud_Driver
Here's a few:
Aluminum Foil tape:
Shape Foil
Thickness .0015"
Length 180'
Width Tolerance ±1/64"
Material Easy-to Form Electrical Grade Aluminum (Alloy 1100)
Finish/Coating Adhesive-Backed
Tolerance Standard
System of Measurement Inch
Material Certification Without Material Certification
Specifications Met Not Rated
6" 8941K24 $97.49
18" 8941K26 248.27
Low-temperature Aluminum Foil tape:
Low Temperature— Has a cold-weather acrylic adhesive that performs well in temperatures below freezing, and has quick-stick ability when applied at normal temperatures. Tape is smooth and conforms to fibrous ducts, sheet metal ducts, and irregular surfaces. Great for vapor sealing fiberglass and duct board, and for foil/scrim/kraft (FSK) systems. Total tape thickness is .003", 50-yd rolls, 1100 alloy.
2" - 7616A21 - 7.21
2 1/2" - 7616A25 - 9.02
3" - 7616A31 - 10.86
4" - 7616A26 - 14.43
I've used this aluminum foil tape and it's quality is comparible to the aluminum foil tape marketed as a model-finishing system.
Stainless Steel Foil Tape
This durable Type 304 stainless steel tape is noncorrosive, nonstaining, and nonmagnetic. It bonds aggressively to metal, making it ideal for patching and splicing stainless steel. Use in marine, food processing, and nuclear applications. Color is metallic silver. Tape has a peel-off liner. Supplied on a cardboard spool with a 3" ID.
Standard Duty— Total tape thickness is .003" and consists of a .0015" thick foil with .0015" of acrylic adhesive. Temperature range is -30° to +350° F. Heavy Duty— Total tape thickness is .0047" and consists of a .0027" thick foil with .002" of acrylic adhesive. Temperature range is -10° to +300° F.
Standard Duty
1" - 76055A694 - $18.48
2" - 76055A695 - 36.95
Heavy Duty
1" - 3-yd - 76055A21 - $6.32, 16-yd - 76055A671 - 22.57
2" - 3-yd - 76055A22 - 12.65, 16-yd - 76055A672 - 45.14
3" - 3-yd - 76055A23 - 18.97, 16-yd - 76055A673 - 67.54
They also have copper-foil tape.
Old 12-24-2005 | 11:08 AM
JetsoverTofield's Avatar
I have ordered these as well.
7429K41-line clips
Old 12-24-2005 | 05:11 PM
Eric.Henderson's Avatar
My wife works for MCMaster-Carr.
It's M'cChristmas most days :-)
Merry Christmas to all,
Eric.
Old 12-24-2005 | 07:43 PM
KFalcon's Avatar
My Feedback: (18)
Thanks, their website can be hard to navigate for some.
Old 12-25-2005 | 10:05 AM
Helijack's Avatar
Navigating their website sucks.
You can add the Hysol 9460 a bit slower set........
Thanks for the list, good job.
Old 12-25-2005 | 03:30 PM
We don't have a McMaster in Australia, can someone suply there contact details ie address to get catalogue, or website etc
Dave Burns Australia
[email protected]
Old 12-25-2005 | 05:17 PM
Topgun2mo's Avatar
My Feedback: (45)
http://www.mcmaster.com/
Old 12-25-2005 | 06:37 PM
Eric,
my regards to your wife. She works for the greatest company on the planet. Nortek, where I work (www.nortek.no), we keep joking that if it was't for Mc Master Carr, we'd go under! Might even be a bit of truth in it.....
Best wishes for the holidays,
- Thore
Old 12-25-2005 | 07:36 PM
When we were in Memphis (where we evacuated to for Hurricane Katrina) there was not a 5 gallon gasoline jug to be found and we needed them to get back home and start the recovery. We called McMaster-Carr and had a bunch of them over-nighted. Saved our bacon!!!
