Ouch! Improper use of retracts...
I've no idea what the real story is behind this but I fell better about any retract issues I've had in the past. Mine only resulted it scuffs and scratches....
From: Auchtermuchty Fife Scotland UK, UNITED KINGDOM
OOPS!
We had an incident close to that at RAF Leuchars in Scotland about 20 years ago.
They had just fitted the last of a set to a Phantom when they turned away there was a loud click, a thud, and a loud woosh. The missile had fallen off the wing, hit the ground, and went off.
Fortunately it only travelled about half a mile, and buried itself in the River Eden which flows just outside the perimeter fence.
I believe the paperwork alone, took about two years to complete.
neat to see a sidewinder fire after hitting the ground!
I believe this is the rest of the story. Or one similar.
http://www.tucsoncitizen.com/local/1...elly_land.html
That appears to be a different aircraft. The first one resembles (a lot) one I saw about two years ago in which the ground crew hit the gear with a car.
My Feedback: (69)
I'm not familiar with the F-16, but here's my guess;
The cart with the hoses running to the plane is probably a hydraulic pressure generator, and the hoses most likely connect to the aircraft hydraulic system. Either the gear handle was in the "up" position and/or the gear wasn't pinned and /or any weight-on-wheels safety was overridden. Anyone know for sure?
In any case.....ouch!
Tom
Tom
