K&b 7.5 Fuel?
My Feedback: (14)
K&b 7.5 Fuel?
Todd try wildcat 15% with 23% oil if you can get it out here meaning california , that seems to be the best for ducted fan , in that catagory of engine size , i fly bvm 91 engines and they like 10% wildcat , the OS 91`s 5% wildcat , however powermaster 15% heli fuel works great on the KB 7.5 engines , do to the higher oil content ,hope that helps .Ed
K&b 7.5 Fuel?
THANKS GUYS FOR ALL OF THE IMPUT. THIS IS GREAT INFO.
DOES ANYONE NO OF A LOCAL HOBBY SHOP IN MY AREA THAT HAS JET FUEL AND TURBINE OIL?? I AM IN LA VERNE CA.
THANKS TODD
THANKS TODD
My Feedback: (21)
WI
K&B 7.5 Fuel
Todd,
Looks like you got the message from some of the other posts, but I thought I'd just toss in my two cents....
Definitely use the PowerMaster 15% sport fuel and then add an ounce of Turbine oil to the gallon (I use Mobile Jet Oil 254... others work as well).
I got this tip from Larry Wolfe of JHH when I picked up my first K&B .48. Most of my K&B experience up till then was with the 9101 7.5 (or earlier 9100!!). I saw a huge difference in over-all performance. I have used WildCat 15% (23% oil) in the 7.5 but stopped because the engine wouldn't turn up as much and ran a lot hotter. The difference is so stark I won't run a 7.5 (or .48) without that fuel/oil combo any more.
Don't get me wrong... I'm not knocking Wildcat fuel, the stuff is great... It's just not the best fuel for this particular application.
If you have questions, don't hesitate to ask.... or better yet, give Larry Wolfe at JHH a call (or e-mail). He's always been very helpful to me and he's out there in CA.
Good luck
Craig
Good luck
Craig
K&b 7.5 Fuel?
THANKS FOR THE INPUT I AM GOING TO THE AIRPORT TODAY TO LOOK FOR SOME TURBINE OIL. I HAVE TAKEN THE MOTOR OUT MOUNTED IT FOR TUNING ON A BOARD.THE PREVIOUS OWNER DRILLED TWO SMALL HOLES WHERE THE ORING GOES AND THE PIPE CONNECTS,HE HAD SMALL SCREWS IN THE HOLES TO HOLD THE PIPE TO THE ENGINE. I WAS TOLD I SHOULD TUNE THE PIPE THIS ENGINE HAS,THE MOTOR,EXHAUST MANIFOLD?THIS IS THE PIECE ATTACHED TO THE MOTOR THAT HAS THE ORING ON IT.THEN IT HAS ABOUT A 4 INCH PIECE OF TUBING, ONE SIDE IS NOTCHED OUT A LITTLE FOR THE ORING TO FIT INTO FROM THE MOTOR,THEN IT HAS THE PIPE. A BOUGHT A RUBBER SLEEVE,IT HEATED UP AND DID NOT WORK, ICANT SEEM TO HOLD THE PIPE TOGETHER.WHAT IS THE BEST METHOD??? THE 4 INCH TUBE IN THE MIDDLE SHOULD IT BE PUSHED ALL THE WAY ONTO THE MAIN PIPE OR ONLY PART WAY AND IF SO HOW DO YOU GET IT TO STAY THERE???? THANKS AGAIN FOR ALL OF YOUR IMPUT I WANT TO GET THIS THING IN THE AIR AGAIN SOON. THANKS TODD
K&b 7.5 Fuel?
Plaincrazy,
Send your email address to me at "[email protected]" and I will forward a copy of the article I wrote for RCJI a year (or so) ago, that described in detail how to set up a tuned pipe on a .45 sized DF engine.
Regards,
Peter
Regards,
Peter
My Feedback: (7)
K&b 7.5 Fuel?
I'm sending you a picture of my mirage drive system ( engine, header, pipe ) not a lot of detail but, I thought it my help. If you need a new o ring for your header and I would change it call Larry at JHH at the same time ask him a question or two, there is no such thing as gas it and go fly it, I'm going through my Mirage, all of it to make sure it is up to my standards.
keep them flying.
Got any more questions?, write any time.
Carlos
keep them flying.
Carlos
K&b 7.5
Originally posted by MiragePilot
Plaincrazy,
Regards,
Peter
Plaincrazy,
Regards,
Peter
