 Stratos Delta >
Stratos Delta
Stratos Delta
Old 02-27-2006 | 01:29 AM
Boomerang1's Avatar
Default Stratos Delta
Hi Guys, posted this in sport models as well. Does anyone have a copy of the plan for a Stratos delta (see pics)? This was about a metre span, made from flat foam & designed for a 40 or thereabouts motor. All I need to know is the dimensions of the wing, simple drawing will do, the CG location & the 'up' trim & control throws of the elevons. I have a friend with a microturbine in a foam delta but the little turbine has a bit too much power & it goes a bit feral. The Stratos was designed by Hanno Prettner & would fly a treat with the baby turbine. - John.
ID:	416539   Click image for larger version
ID:	416540   Click image for larger version
Old 02-27-2006 | 02:21 PM
Default RE: Stratos Delta
Hi,
I have a copy of the original plan. Sent you an E mail to see how you would like the info.
Alan
( In original South Wales)
Old 02-27-2006 | 03:06 PM
Boomerang1's Avatar
Recieved your email Alan, reply on the way, thanks. Just noticed in the background of the red model pic is a Multiplex Twinjet, the model currently powered (over powered?!) by the turbine. - John. (NEW South Wales)
