 Ideal engine thrust for the SM Bae Hawk >
Old 03-27-2006 | 10:00 AM
Ragz's Avatar
Default Ideal engine thrust for the SM Bae Hawk
What thrust class engines are being currently used on the SM Hawk. The finished dry weight is estimated at around 25lbs. Should it be 18lbs or a 28lbs engine? I know it CAN BE flown with smaller ones too...but what thrust is BEST SUITED for overall performance.
Old 03-27-2006 | 11:00 AM
Vincent's Avatar
My Feedback: (61)
Default RE: Ideal engine thrust for the SM Bae Hawk
P-120 for sure. V..
Old 03-27-2006 | 12:08 PM
JohnMac's Avatar
Well I flew one with a Wren 54 Mk 3. For me the model looked perfectly scale. It was neither under or over powered. With a Jetcat P120 it would no doubt be a lot of fun, but way overpowered for scale. I think the absolute perfect engine would be a Wren Supersport. Same weight and physical layout as the 54 but that bit more power if you ever need it.
Regards,
John
Old 03-27-2006 | 12:16 PM
My Feedback: (61)
Not mentioning Manufacturers as the original question, I've flown one with a 18 lbs thrust and a 27lb thrust and they were both the same when flying scale like. BUT it was more fun to have the extra power for certain vertical and slow / high alpha passes.
Adil
Old 03-27-2006 | 02:33 PM
Banned
My Feedback: (67)
P-120 for sure. I just witnessed the maiden of one powered by a Titan and it's waaaaay too much, even the owner made the same comment. Flies great by the way.
Old 03-27-2006 | 02:36 PM
Ali's Avatar
Ali
I have flown this model with turbines ranging from 16lbs of thrust right up to 30. I have to admit that I had the most fun with the P-120. It flys just as scale with a more powerful turbine, it just means you use the throttle stick more frequently. I did fly it with the Supersport and although it flew it and it was very light to fly, oh and it flew for 20 mins on a tank I did not really like it. It always felt like it wanted 10% more. In retrospect i think a full bypass would have made this difference. But in the end I went back to the old trusty 120. Takeoff at half power (for scale) then cruise at half or just under. Aeros at 3/4 and slowflight to vertical with full power ..... Oh Yes!
The turbine was not working it's nuts off and fuel lasted ages.
Regards Al
Old 03-27-2006 | 03:35 PM
My Feedback: (61)
Hi Ali,
Thanks for your experiences with different engines. The planes I test flew were of friends but I liked it so much, I got one as well. Here is a preview picture of it as it is being pained. It is not exactly scale but I wanted it this way. I like it better than the scale picture in the background. this will be getting a 27lb engine to have fun with.
Thanks - Adil
Old 03-27-2006 | 03:51 PM
Ali's Avatar
Ali
Adil You stole my idea
I was thinking exactly the same thing. The idea behind the real hawk/dragon combo was great. Just a shame they let the c=local junior school apply the art work.
Yours is looking great even now so when its done I am sure it will be just as stunning as your other jets
Old 03-27-2006 | 04:18 PM
My Feedback: (61)
ORIGINAL: Ali
Exactly
Well - good looking planes is one thing, I just need to get my flying skills up to par (somewhere between mine[] and YOUR level) and then I'll be happy.
I'll post some more pictures when its done.
Adil
Old 03-27-2006 | 04:51 PM
Robrow's Avatar
I have wanted to try this Hawk with the Jet Central Falcon engine, 22lbs thrust, 3lbs weight and somewhere in between the SS and 120 in frontal area/diameter.
I've heard and seen so many people praise the flying qualities of this version of the Hawk.
Rob.
ID:	434121   Click image for larger version
Old 03-27-2006 | 05:02 PM
Ali's Avatar
Ali
Sounds like a spot on choice Rob.
Adil So what you are trying to say is that your flying dosent need much if any improvment then Keep me updated when you get that Hawk finished. I would love to add it to my gallery.
Old 03-27-2006 | 06:13 PM
Guest
My Feedback: (73)
ORIGINAL: Adil Nasim
Hi Ali,
Thanks - Adil
ahh ! another paint job by Chipo from www.apwpaint.com ... you just could not help yourself could you Adil ?? looking forward to seeing it fly ...
Voy
Old 03-28-2006 | 12:45 AM
Ragz's Avatar
Thanks for the advice guys. So its gonna be a 120 alright
