 Why not throttle curve in ECU? >
Old 05-27-2006 | 09:39 PM
Edgar Perez's Avatar
My Feedback: (13)
Default Why not throttle curve in ECU?
Tomorrow I will try, for the first time, a throttle curve in my transmitter to get a more linear response in thrust.
However I was wondering, why the manufacturers do not adjust their ECU so that once the radio is trained, the ECU will adjust itself to get a linear thrust response. Since the manufacturer know how its turbine characteristics, the ECU will seem the best place to perform the adjustment.
Edgar
Old 05-27-2006 | 11:20 PM
grbaker's Avatar
My Feedback: (29)
Default RE: Why not throttle curve in ECU?
Good Question!!!
Old 05-27-2006 | 11:56 PM
Boomerang1's Avatar
There's a thread here somewhere where someone used negative expo to make the throttle more linear. - John.
Old 05-28-2006 | 12:00 AM
erbroens's Avatar
I guess because it is better to have a wider and less sensitive thrust curve at less than 50% stick, where you need to "fine tune" the thrust setting for landing approach.
Anyway it is quick and easy to set a throttle curve on any Tx...
Enrique
Old 05-28-2006 | 04:30 AM
My Feedback: (10)
ORIGINAL: Edgar Perez
Edgar
if you have a good responsive turbine there is no need for this is there?
Old 05-28-2006 | 05:48 AM
I think some turbine will flame out if your stick percentage is too close the turbine spool up time.
Old 05-28-2006 | 05:30 PM
CARS II's Avatar
My Feedback: (7)
I added 20% to the throttle curb at the mid point and the radio adjusted the throttle curb for the rest of it, top and bottom. I think that 20% to 25% to the mid point is a good start, so far I like it, I'm getting a nicer respond as I get closer to the mid point.
