What turbine to use for the Yellow A-4 Skyhawk??
My Feedback: (17)
Hey guys, canyou tell me whisc is better in terms of reliability, the Jetcat P-60, or the Wren-44 gold with autostart. I know the Jetcat has 13lbs of thrust comared to the wren @ 8lbs, but I dont need tons of power because its going into my Yellow ARF A-4 Skyhawk that weighs about 9-10lbs 56" length 40" wing span. What do you gus think? Bothe cost the same.....$2495.00
-John
-John
My Feedback: (49)
RE: What turbine to use for the Yellow A-4 Skyhawk??
I dont own either one but Ive seen a few of each at different jet events. For the A-4 Id be inclined to go with the Wren for reasons like size, weight and fuel burn. On the other hand the P-60 might be the way to go because it can power a wider range of larger airplanes down the road. From what little I know they are both fine engines and Im sure you'll be quite pleased with either one.
My Feedback: (57)
Will 8lbs be ebough for that kit? I mean, I've seen it with a Dynamax and it flies pretty marginal.
I'm no turbine expert by any means, but a P-60 will fit on far more airframes than a 44mm. Wren 44 is great for those very few Sierra airframes and similar.
Good luck!
David
Good luck!
David
My Feedback: (17)
I still got the Heli's and they are still cool.....but I'm and X-Air Force F-16 Pilot who loves Jets! Guys, how is the p-60 more Versitile? I was told that you lose some thrust when you put the P-60 in a jet, compared to not losing anything with the wren-44. Also, how did you get the wren turbin up to 14lbs of thrust?
-John "The Rookie"
-John "The Rookie"
My Feedback: (9)
CA
John,
ALL turbines, even the Wrens, lose a little thrust when they push the exaust through a pipe. They lose no thrust only in a pipless airframe like a Bobcat or the like...
I think what Shok meant in his statement was, he has flown the 44 in airframes up to 14lbs. in weight, not thrust.
My Feedback: (17)
8 lbs. is plenty of thrust for the Yellow A-4. Before JetCat, before the "Hammer," Bob Wilcox flew a Yellow A-4 with an FD 3/67 and it was awesome. Remember the Golden West Turbine?
My Feedback: (29)
You just can't compare the static thrust ratings of DFs to the thrust rating of turbines. They're not the same animal.
My Feedback: (49)
Im not certain about this but I think the Wren tailpipe design still has a thrust decrease, it is just LESS of a decrease than a straight thru constant diameter pipe. I dont think it is actualy a thrust increase. I'll certainly stand corrected if Im mistaken.
The Wren 44 is plenty of power for this airplane assuming it is done correctly.
I beleive they call it the "Wren Thrust Augmenting Pipe". It increases thrust but I don't know off hand by how much or what sizes besides the 54 is available. There is a formula for the dimensions that would apply to all engines.
These pipes have a diferent shape. The first get wider, and then have a cylindrical shape. The thrust increase is paid with a loss of thrustvelocity.
My Feedback: (29)
The Wren thrust augmenting pipe design does increase thrust.
I used the Wren (John Wright) design specs when I built a pipe for a JetCat Titan in a Eurosport. I got a 3 pound thrust increase using this pipe as compared to running the engine with no tailpipe.
Yes, I was thinking that maybe there is an increase in static thrust but a decrease in velocity but haven't really read up on it.
My Feedback: (49)
Ok, I stand corrected. So now if i understand correctly an increase in static thrust would mean greater acceleration ? And a decrease in exhaust velocity would mean a reduced top speed of the airplane ?
