Yellow F-18 twin brakes, Help!!
RE: Yellow F-18 twin brakes, Help!!
Hi,
Joe's right. The current brake system for this bird is righteous. Those fuel-tubing brakes are not up to snuff for turbine use (if at all). I'll be happy to set you up with some. Just give me a call or an email.
My Feedback: (10)
FL
The newer model brakes (been sold for about 18 months now) for the 18 are made either by BVM or under contract from a BVM design. They work great and are easy to install with your current gear. You can purchase them direct from YAI.
My Feedback: (21)
you can also use BVM F-4 wheels and brakes with minor modifications as a short term fix. by minor I mean minimal grinding to get the brake hub snug against the lower leg.
good luck
buck
can't wait to reacquire the big bird and start the project once I get my feet on the ground out here.
good luck
buck
