Newbie brake question. >
Old 12-30-2002 | 10:58 PM
SJN
Default Newbie brake question.
I have got some Eurokit brakes wheels, and gear.
But I didn`t get any instructions with it.
I havn`t played around with these things before, so I havn`t got a clue on how the work
Well, the brake and wheel assy slip rigt on to the axel perfectly.
But isn`t the brake supposed to be fixed to the gear somehow, so it doesn`t rotate with the wheel? I mean, the brake hose souldn`t be the only thing to stop it rotating ?
I have a link to a PDF file where the brakes are at the bottom.
http://www.eurokitlucca.it/PDF/ModelAccEstInt.pdf
Thanks... SJ.
Old 12-31-2002 | 11:19 AM
My Feedback: (8)
Default brake hose ?
You are right the brake hose will not stop the rotation. You need some type of channel for the brake assembly to fit into so the brake system will not rotate. Mike
Old 12-31-2002 | 02:30 PM
SJN
ok thanks.....
I saw some pictures, and can se that my brakes don`t fit the type of gear I have, unless I do some modifications.
SJ.
