New Version JetCat P-120 ECU
My Feedback: (85)
I sent in my P-120 ECU to JetCat for the 5.0X upgrade---I was informed by Jason that I am receiving an even newer upgrade version...5.1E!!! The newest ECU flash 5.1E enables you to not only get the great acceleration from the 5.0X but you don't loose any of your info when a newer program version is flashed to the ECU...In the past when you had the ECU flashed you lost all of your stats...Not any more!!!
Kevin
Kevin
NY
Bob, as I understand it the major improvment in the throttle response time is above half position and above. You also do not have to reclibrate your temp probe after having the ecu updated.
Don
Don
