 9ZAP programing for Wheel brakes >
Old 07-31-2006 | 01:52 PM
Default 9ZAP programing for Wheel brakes
I would like to set up my wheel brakes to operate with down elevator but only when the wheels are down to save on air.
Can anyone advise on how to set up the mixing for this:
Arthur
Old 07-31-2006 | 01:57 PM
Default RE: 9ZAP programing for Wheel brakes
Set the gear switch to activate a PMIX.
Set up the PMIX with elevator as master and brakes as slave. Bingo, job done.
I am sure there are other ways of doing it too.
Obviously this will rely on having a seperate channel available for brakes. If you do have a spare channel then why not have a seperate control? I use the right slider for wheel brakes and this gives me full control whenever I want it.
Old 08-01-2006 | 03:09 AM
Old 08-01-2006 | 05:39 AM
Thats the way I have set it up as well. You might need to setup a non-linear mix otherwise you can get over aggressive braking and a not very smooth stop...
