Nitro models pusher Bobcat?
#1276
NY
RE: Nitro models pusher Bobcat?
i balanced the jet around 10.5 with standard servos in the tail.. i added about 7 ounces to the tippy tip nose of fishing weights.
#1277
OK fellas, I just joined the Bobcat 50 club! I've been following this thread since its inception, and saving my pennies. Several times I went to the Nitro Web site ready to buy but I just couldn't convince myself to spend that much on shipping. Today I went to my local hobby shop to pick up some small parts and I happened to ask they guy behind the counter if he was familiar with the Bobcat 50. He thought for a moment and then said, "oh yea, we have one of those". I got goose bumps, then I thought, he must be mistaken. Sure enough he pulled the kit down from the shelf and behold, there it was, it must be DESTINY!!. So to make a really long post short, I bought mine today for $120 plus tax, no shipping. See you in the air......
Chris
Chris
#1280
My Feedback: (927)
I have had a large number of requests for the photos of the turbine conversion made on my Bobcat. There are a lot of photos so I have done the following;
I will be posting a "How to " article on my web site.
I have about 8 pages done and am almost finished. I'm down to last of the internal install of the mass of wires cables fuel lines etc. It's a very detailed conversion of the Bobcat for turbine use.
Watch for it soon.
It will be at,
www.SouthFloridaJetTogether.com_
(http://www.SouthFloridaJetTogether.com)
Thank you all for the interest.
Any comments would be greatly appreciated. But remember this is the first time I ever tried documenting a project. So please be gentle.
Should be up in about a week or so.
HapyJac
Watch for it soon.
It will be at,
HapyJac
#1281
My Feedback: (23)
UT
I finally broke down and ordered the Bobcat. I am looking at putting a rear exhaust .60 on it with a pipe. Now for the question, what is going to happen when I extend the exhaust of the tuned pipe 180 degrees???????
#1282
ORIGINAL: sticks-RCU
The gooey stuff will exit to the rear of the plane.
I couldn't resist...
#1283
IL
#1284
My Feedback: (23)
UT
ha ha ha ha ha, This is not a DF engine, it is I believe a YS .61 rear exhaust engine. The pipe is just a straight tuned pipe, but i don't think it is a good idea for the exiting hole of the pipe to be pointing towards the front of the plane. I could be wrong, but I think this is going to cause some sort of problem. What I was planning to do is use a piece of copper tubing or something similar to make a U shape exhaust extension. Can I get any takers on if this is going to work or cause a problem.
#1285
IL
There's not a lot of room between the rear of the fuse and the engine. You may be able to fab some type of 90 degree elbow and mount the pipe pointing either left or right. I doubt there's room to turn the exhaust 180 degrees and point the pipe to the rear. The stock type header and muffler may be a better choice.
#1288
IL
Well on another note, if you want to see an optional use for Jet-Cat turbines, go to Yahoo videos and check out the clip titled: THE INCREDIBLE FLYING MAN
#1289
AB, CANADA
It's possible that I missed some posts but I don't remember any tuned pipe installs on a rear exhaust engine.
#1290
ORIGINAL: Stick Jammer
Mark
#1291
AB, CANADA
I think I remember one post where the person used a header from an R/C car tuned pipe to redirect the exhaust.
For a tuned pipe solution, you have to go all the way back to page 16 of this thread:
#1292
MO
The guy from Mac Products said he is working on a "candy cane" that would turn the exhaust 180 to the back of the plane. He should have it ready in 3-4 weeks for about $30-$40.
#1293
OH
I like the way someone did it an previous post they took some clear tubing and drilled through the fuse ran it out the bottom a freind and i have each built one [havent flown yet still 2 cold] he has done his im gettin ready 2 do mine cost was $1 for tubing and some silicone seems like the best and most inexpensive way 2 do it and it doesnt look all that bad
Just my 2 cents
Jason
EVERY STINKIN PENNY SAVED HELPS !!!!!!!!!!!!!!!!!!
here they are
Just my 2 cents
Jason
here they are
#1294
IL
Thanks for jarring my memory [sm=71_71.gif] I do recall that picture (great job by the way). It's hell to get old. [sm=spinnyeyes.gif]
#1298
My Feedback: (8)
I used a Pitts Muffler on my Bobcat with an OS 46. Worked great (until I was shot down this past weekend).
I'm looking at the Kee-Cat next, I like retracts (but don't have time to work them into another Bobcat, 2 jobs=not enough time).
mark
mark
#1299
I do like the Keecat but I can't compare it to the Bobcat since I've never had one. The retracts seem to be pretty good for the money. I fly from a very rough field and have about ten flights on the Keecat. The whole kit is about $200 with the retracts. If you do go with the Keecat, just be aware that the CG seems to be way off in the instruction booklet. I balanced mine an inch and one half forward of where the instructions show it! I don't know how they can be that far off, but they are.
#1300
My Feedback: (23)
UT
Wayne22,
Nice job, I really like what you did. Has anyone looked at mounting their engine inverted? If I do this I will eliminate having to buy a new header for my YS .60FR if I could even find one. If I do invert the engine I will have to make sure that there is enough air movement over the engine so it doesn't overheat.
One more thing, when I test fit the wings the through hole for the wing tube is not centered. I have one wing with a 1/4" gap and the leading edge and the other wing with a 1/4" gap at the trailing edge. Has anyone else had this problem?
