Engine install question...
My Feedback: (27)
All,
I am installing a Rhino in a SM F-18F with a TAM pipe and need to know what the distance should be between the pipe inlet and the end of the engine. Eric told me but I forgot.
For some reason, 3/4" is ringing a bell.
Any know the answer?
Beave
Beave
My Feedback: (49)
I've searched all the RCU postings on the subject and 1/2" to 3/4" seems to be the range most use. I used 1/2" for my Artes Falcon/Gripen and it worked fine.
Each application is a bit different. I suggest that you contact Eric Clapp at JetArtes Gulf Coast, or post the question in the Turbine Clinic.
Joe
Joe
In testing, we obtained the best result at 40mm (1 1/2") from the exhaust cone to the beginning of the main diameter of the pipe, not including the bell mouth
