 Rookie 2 thrust vector/engine nozzle overlap. >
Old 10-14-2006 | 05:36 AM
Robrow's Avatar
Default Rookie 2 thrust vector/engine nozzle overlap.
Hi, just doing engine install in Rookie 2 and was wondering what distance of overlap other owners have between the vector nozzle and engine exhaust. Mine is quite far back in the mounts so the front of the vector nozzle is not far off the rear of the engine casing, I need to shorten the front of it.
Rob.
Old 10-14-2006 | 08:00 AM
Default RE: Rookie 2 thrust vector/engine nozzle overlap.
Hi Rob
I had to scoop out the tail cone top and bottom to fit the curvature of the engine tail cone.
ps has the auto start fadec arrived yet for my jg3000 ?
cheers
Old 10-14-2006 | 11:10 AM
Robrow's Avatar
Thanks for reply; ecu shipment is in transit, should be here mid next week, give me a bell then.
Cheers
Rob.
Old 10-14-2006 | 11:50 AM
Rob
I set a JetCat P120/160 with a big exhaust so that there is a 5mm over lap at full vector
Regards
Dave
Old 11-06-2006 | 05:35 PM
My Feedback: (51)
Who is the manufacturer of this unit ?and how did it work out ?
Old 12-30-2014 | 06:29 PM
My Feedback: (91)
What are you guys using to make the pushrods? With the high temps I heard metal rods transfer too much of the heat to the servo. So I was thinking carbon fiber rods. However what do you use to secure the threaded rod. Glue it in with ca? Jb weld?
