skymaster f-15 and p-120
My Feedback: (23)
Hey everybody...
well i change my turbine on my f-15 and i went bigger ..p-120 on the set up with a bypass system
now and my waith stop at 13 kilos dry.....im going to fly her for the first time with this engine in the next days
and i would like to know from owners with same set up what is your minimum level flite engines rpms on an f-15 with the p-120
and how many rpms you hold on touch down....
always aproxymatly this numbers so i can get an idea...
this info will help me to get ready better becose i think the sink rate will get bigger and i think i must drive more hot..
thank you in advanse for any info my friends
sorry for my bad english
RE: skymaster f-15 and p-120
You will have no problems with the P-120 on this plane... you will love it. Flying it at 60% throttle is typical... 100% is only used at takeoff or for vertical pushes. My landing procedure in this plane is no flaps and 1 or 2 gear inspection flybys over the landing strip to set the proper visual approach speed (about 50 % throttle), based on the current wind condition... Then reducing it to about 30% on the final ramp approach chopping the power just before the plane reaches the runway heading.Pull the nose of the plane up as much as you can at touchdown.. it won´t tip stall.
Just pay attention on the nose up angle of the plane.. if the nose gets up too high on the landing approach you will need a lot of power.. the plane has lot´s of drag in this condition.
Good luck with it,
Enrique
Good luck with it,
Enrique
