DF Help
My Feedback: (10)
NE
you can but, i would'nt advise it. you will burn it up rather quickly. you need to run the lowest nitro that you can get with the highest oil content. i run 5%nitro with 20% oil. i have buddys that special order there fuel with 0% nitro and 23% oil. i run my motors a little rich also. are you running this motor in a heli?? if you are you will want the byron head on also. you will need the large head to help cool the motor.... good luck donniercjet
My Feedback: (49)
I always ran my OS91's on 10% nitro. 15% is a bit high. If you already have the fuel and want to try it I'd recommend adding another head shim.
What % oil is in the heli mix? You need at least 20%, and it should be a synthetic/castor blend.
Your best bet is to order some Wildcat Jet-A DF fuel in either 5 or 10% nitro. It has about 23% oil.
Joe
Joe
Hi
Order the Wildcat DF 5%. In my experience it runs better than 10%. Mine has about 30 flights, and I'm on the second glow plug and no dead sticks yet (knock on wood)
Regards
Eduardo
.Regards
Eduardo
