Foam Wing Cutting
If Kerry can't help you, I've had Bob from www.flyingfoam.com make jet wings for me in the past. Also, Htail and Vtail surfaces too. He did an excellent job, and I'd use his services again.
I've also used flyingfoam.com. Bob cuts nice cores with his NC foam cutter. Moved from CA to just north of Austin, TX in the last year. Can cut anhedral, dihedral, washout, in a variety of foams and densities.
