Ram 500 >
Ram 500
Ram 500
Old 01-27-2003 | 01:15 AM
B58
My Feedback: (43)
Default Ram 500
Is a new Ram 500 a good buy at $1600, or is it better to go the extra bucks and get a Jetcat or some other engine. First turbine, and I am tempted. Any advice would be appreciated.
Old 01-27-2003 | 01:39 AM
Default Good Buy?
Hi B58
That would depend upon what airframe you were considering putting it in. If it's a DF style airframe designed around a Ramtec(Dynamax)/OS91 setup, then it's probably a good buy. If your looking at some larger airframe, then I might suggest that you look for a larger engine. There's also the lack of warranty support for these enges, although I know Carlos does an excellent job with them.
Think about where you want to got and if the 500 will suit what you want to do. BTW, what airframes were you thinking of?
Ed
Old 01-27-2003 | 02:38 AM
Terry Holston's Avatar
Default Ram 500
If the serial Number is less than #150, then it will need about 300 Bucks worth of Carlos "Magic" to make it run right!!!!!
If the # is greater than that go for it!
Old 01-27-2003 | 02:58 AM
David Gladwin's Avatar
Default Ram 500
If anyone is interested my RAM 500 is for sale. It was fitted with newest electronics and "breathed on" by Carlos at last FJ, runs beautifully and starts first time with SCR batteries. Powered my BobCat for 50 flights and is in perfect condition. Can deliver at FJ for US$1600.
I also have an AMT Pegasus in perfect condition which powered my BVM F4 for 30 flights before being replaced by Peg HP.
Pefect engine US $2000
Can deliver at FJ.
BRG,
David Gladwin .
Old 01-27-2003 | 03:43 AM
B58
My Feedback: (43)
Default Ram 500
I was thinking of my YA A-4 that is at the right stage. I will think about it and find out what serial number. Thanks for the help. I have seen the Jetcat, and know they work fine.
Old 01-27-2003 | 06:42 PM
Default small Turbine
But the best choice would be the FS 52 from FunSonic. It is smaller and not so heavy.
TO
www.funsonic.com
Old 01-27-2003 | 07:56 PM
cactusflyer's Avatar
Default Ram 500
Or if you want the most satisfaction for your $$$, the Wren MW54! This way you can work on it yourself and not worry about what serial number it is or who built it that week.
See: www.wren-turbines.com
You won't be disappointed!
'Beat you to it , Andrew!!!
John
