over powered??????????? >
Old 01-28-2003 | 12:25 AM
My Feedback: (17)
Default over powered???????????
hey guys, my question to this panel of experts is. i have a knights of air mig 15, the person i bought it from was setting it up for a single dynamax fan unit, i want to convert to either two byrons, or dynamax fans and use 2 os 91's, is this too much power? i think it will have plenty for roll and lift off of grass, and i can throttle back once in the air. but with the 91's am i making a mistake???
Old 01-28-2003 | 12:33 AM
My Feedback: (17)
Default correction
i'm sorry, but i ment to type MIG 25
Old 01-28-2003 | 02:12 AM
JohnVH's Avatar
My Feedback: (38)
From what I have seen, there is no over powered around these turbine guys.
Old 01-28-2003 | 02:34 AM
Terry Holston's Avatar
Weight might be the problem, if there is one. what is the W/S, Length and weight now as a single?
Old 01-29-2003 | 04:51 PM
Tim Redelman's Avatar
My Feedback: (36)
Thers no such thing as "To much power" in a ducted fan! IMHO.
Tim
Old 01-30-2003 | 03:19 AM
My Feedback: (17)
Default statistics
ok, maybe this will help,
lenght 75 inches
wing span 46.5 inches
wing area 757 inches
weight 16 lbs
recomended engines 2- .75's.
so this is why i am here, will two 90's be to much?
thanks for the help
mark
Old 01-30-2003 | 03:27 AM
Banned
My Feedback: (119)
Nope. The KOTA planes came out pretty heavy, usually, and you can really use the extra power.
I beleive the original setup on that plane was two Byron fans in the first place.
Old 01-30-2003 | 03:31 AM
My Feedback: (17)
the person who started to build this jet , installed the formers for a single fan, dynamax. but also sent me the formers for a dual fan set up, i already have a pair of dynamax fans, not installed yet, but i would think the byrons would work better with 2 - os 91's or rossi 90's
mark
Old 01-30-2003 | 03:43 AM
Banned
My Feedback: (119)
I think twin byron would be better. You are right. The ducting is primitive on these planes(no intake ducting at all, right?) and twin byron is a lot easier than twin dynamax. Lower revs, less vibration and stress. You REALLY need to have your act together to do twin dynamax...you get all sorts of weird failures from vibration if all is not JUST SO. Gotta hand it to the Tom Cooks and such who mastered those types of planes!
I would knock out the former and put in the proper one, for twin byron. I understand this plane flies pretty good in the original setup, though I have not flown it myself.
