 Fuel line ? >
Fuel line ?
Fuel line ?
Old 04-01-2007 | 10:53 AM
My Feedback: (9)
Default Fuel line ?
I am setting up my baby boomer with the jet tech tank and wren 54 ss. The wren has small fuel lines but my tank and uat have 6mil lines. Where can I get adaptors?
Old 04-01-2007 | 11:03 AM
My Feedback: (38)
Default RE: Fuel line ?
You can make your own using brass tubing, telescope down to what you want and solder together. Or, you can call your friendly Festo supplier and get what you need. Either way will work.
Old 04-01-2007 | 11:57 AM
My Feedback: (57)
Should be able to find what you need [link=http://dreamworksrc.com/catalog/index.php?cPath=63&sort=products_sort_order&page=3]here[/link].
Old 04-01-2007 | 03:44 PM
swansons's Avatar
Festo # FES-5499 4MM to 6MM connector @ Dreamworks for $2.95.
John S.
Old 04-01-2007 | 07:25 PM
My Feedback: (9)
Thanks fellas.
Old 04-02-2007 | 12:42 AM
If you are using the clear 6mm and 4mm tubing. Its easier. The 4mm tube have a OD that fits nice and tight into the 6mm ID.
I fit a short piece of 4mm onto the fuel pump (about 15mm) and than slip the 6mm tube coming from the UAT over the 4mm line all the way onto the nipple on the fuel pump. Its a tight fit and holds very well.
