Fuel Oil mix?
RE: Fuel Oil mix?
Same here. 7.68 oz. (US Liquid) in 2 gal. (US Liquid)
Now, if you guys were using the metric system, it would be rather easy. 30 milliliters per 1 liter. No calculator required. (1 liter = 1000 milliliters. 3% of 1000 is 30.)
For myself, I mix up 20 liters at a time. A 3% mix is 600 milliliters. (5% is 1 liter.)
...jim
...jim
My Feedback: (69)
RE: Fuel Oil mix?
ORIGINAL: JimBrown
...jim
...jim
The USA IS moving towards the metric system "inch by inch!"
BTW...I just bought 12 feet of 6mm cable at the hardware store.....
Dave
RE: Fuel Oil mix?
ORIGINAL: JimBrown
...jim
...jim
then for 5%, 19 liters kero and 1 liter oil and not 20 liters kero and 1 liter oil...
OK?
Regards
RE: Fuel Oil mix?
ORIGINAL: S_Ciambra
Hi Jim,
OK?
Regards
Hi Jim,
OK?
Regards
That's the way i mix, for 5% i add the quart of turbine oil, then add 4 3/4 gallon Kero.
kc
My Feedback: (10)
RE: Fuel Oil mix?
KC,
I don't believe you have a 5% ratio. 5 gal is 640 oz., and 5% of that is 32 oz. Thus you should mix 1 quart oil to 5 gal, which is 20 to 1, or 5%. You have a 19 to 1 ratio.
My 2c.
Bob
My 2c.
Bob
My Feedback: (48)
RE: Fuel Oil mix?
Some of you guys need to go back to school.
If you have a total of 5 gallons, 4 3/4 gallons of fuel and one quart (1/4 gallon) of oil then you have 5% oil. 32 oz. oil/640 oz. total = 5.00%
If you have 5 gallons of fuel plus a quart of oil then you have a total of 5 1/4 gallons or 672 oz. (640 + 32). 32 oz. oil/672 oz. = 4.76%.
Joe
Joe
RE: Fuel Oil mix?
yes 5% of 5 gallon (640 oz) is 32 oz, in order to have a 5% ratio you have to take the 32 oz of Kero away so the total end product is 5 gallon, if you add the quart to 5 gallon you then have 672 oz, not a 5% ratio. and in most cases i mix by the gallon because my turbine oil comes in 7.5oz cans, i mix that to a whole gallon and it's very marginally over 5%.
also a 20-1 ratio is 4.76%, not 5 just so you know.
kc
EDIT: i see i posted the same time as joeflyer with the same responses
to elaborate a bit further 20-1 is a 21 part mixture, as mentioned it's time for some folks to go back to school, Are you smarter then a 5th grader
kc
RE: Fuel Oil mix?
ORIGINAL: causeitflies-RCU
It's a good thing we don't have to be TOO precise
kc
RE: Fuel Oil mix?
ORIGINAL: afterburner
Is it apparent to anyone else after reading this thread that there's nothing happening in the RC Jet community this evening?
Marty
Marty
kc
