couple more questions?
ok guys, gonna pick brains again.
#1 what kind of recieverpack should i use, current one is 600mah 4cell (for a jet?) i am thinking of a 5 cell 2400 mah
#2 how can i identify my fan unit in my f16?
#3 how can i set up my steering gear for my f16 so there is no slop. shoud i set up a pull pull system?
#4 where can i get a starter wand
#5 what type of fuel shoud i use (i use coolpower 15% in my sport planes currently)
btw this is a yellow f16A with sport retracts os 91 df not sure which fan unit. tons of paint to strip off. good spring project.
thanks for all the help sofar guys, this is my favorite website!!!
#1. 600 mah should be fine if you aren't using power hungry servos. As with any plane check the battery before every flight with a loaded meter.
#2 take a picture and post it here
#3 see #2
#4 Yellow aircraft or the for sale section here on RCU
#5 Wildcat ducted fann fuel 5% or 10%
Mark M
#3 see #2
Mark M
My Feedback: (8)
"#2 how can i identify my fan unit in my f16? "
I would guess the fan unit is a Dynamax since that is what the Yellow aircraft jets seem to be designed around. Count the rotor blades. If there are 11 blades, it is definitely a Dynamax. If there are 9 blades, then it is likely to be a Ramtec fan. It is not likely that it is a BVM fan. The BVM rotor has 7 blades.
ok fan is dynamax, 11 blades. thanks for the answers. i dont have a digital camera. i will check with the lhs owner who is into jets, he has a turbine and building a jet, he can help me with steering setup.
