Thrust Tube!!! >
Thrust Tube!!!
Thrust Tube!!!
Old 02-27-2003 | 03:53 PM
Default Thrust Tube!!!
Hello!!!
I was wondering what are good materials to make the thrust tubes for ducted fans???
Old 02-27-2003 | 10:26 PM
jason's Avatar
glass cloth on a piece of window glass with epoxy carded on to it then when set you can peal it off and bend it to make your tube.
jason
Old 03-17-2003 | 08:18 PM
Do you mix the epoxy with denatured alcohol or do you spread the epoxy by itself??? Also, do you coat the window glass with anything or does it peel off with relative ease??? Thanks for the info!!!!!!
