 ProJet ECU help! >
ProJet ECU help!
ProJet ECU help!
Old 05-27-2007 | 08:26 PM
InboundLZ's Avatar
My Feedback: (10)
Default ProJet ECU help!
Need some help...
I have a Behotec J66 engine with a ProJet ECU. I am trying to set/access the loss of signal shutdown parameters. Currently, if I shut down the TX the engine does not failsafe shutdown due to loss of signal. I have read the book and can not find how to set this up on the ECU.
For now, I have the RX failsafe set up to shut down the engine in a failsafe condition. I would like to get it to work via the ECU.
Anyone know how to set this up?
TIA!
Old 05-28-2007 | 04:35 AM
Default RE: ProJet ECU help!
Hi
i have also a projet ecu for my Behotec jb130.
there is no failsafe setting in the ecu .
I have also like you set the failsafe setting thru the TX wherby it goes to idle when in failsafe.
hope this helps
Old 05-28-2007 | 08:20 AM
in the projet ecu there are "aux" channel..
you can plug in one of your free channel of TX-RX and set "shutdown" this channel in fail safe
situation...
Old 05-28-2007 | 08:53 AM
ORIGINAL: chrigui
situation...
forgot to write that to thanks chriqui
