Bob Cat Copy Falcon 120 Jet
#5076
Hello Woketman,
I am the videographer; the Flacon 120 has split flaps. On this flight it appears he landed with no flaps. On this day the winds were high and crosswind. If you look at the trees in the background, you can clearly see them dancing.
Cheers!
Desert Fox 1
Cheers!
Desert Fox 1
#5077
Hmmm.... "splt flaps"?
Mine doesn't have any flaps. In fact, it looks like a totally different airframe (??)
My wings come out a few cm from from the fuselage, then the boom slots in, then the outer wings slot over all that.
Maybe what I've got isn't really a Bobcat Falcon 120 after all?
BJ
BJ
#5078
BJ
BJ
My Falcon 120, all the ones I have seen, had balsa wings/tail and moulded/painted fibreglass fuselage with a moulded plastic canopy/hatch. The tail booms were bolted to the top of the wing from below, around mid-span of the split flap, thus allowing the flap to extend inboard and outboard (and even under) the boom. A platform was moulded into the fuselage and the engine (turbine or 120 2-stroke) was mounted on that.
Wingspan 63 inches. What's yours?
Falcon kit (apart from canopy and fixed gear supplied) out of the box
Wing underside, show split flap
Home-made tank moulded from this carved foam pattern
#5079
Thanks Alasdair.
And yep - totally different.
The main fewz is glass. The top of the nose is balsa.
Wings are iron-on over balsa ribs and hardwood (?) spars.
Tail booms and cross-bridge elevator the same. The booms look a bit 'light' - not as robust as I would have thought they would be. Rather flimsy, TBH.
No mounting platform at the rear of the fewz. No flaps of any kind.
Totally different structure and layout compared to your pics. I'll take a few pics of my jobbie from overhead for comparison.
No big deal either way. If I can't fly it, I can Hangar Queen it from a ceiling some time maybe.
Having said that, I'm still not sure what servo's are the recommended ones - even more-so finding out what I have is not really a Bobcat Falcon 120.
Meh - chuck it off a cliff to see if it will Slope Soar maybe?
BJ
BJ
#5080
Last year I built a turbine powered scale HS Trident, as simple as possible, and to get it down I had to kill the engine. I gave in and retro-fitted flaps.
#5082
The only question is how much space do you have to land it. Of course it will land just fine without flaps.
The falcon 120 flaps are split flaps. The work very well but they are pretty much air brakes. You can slow the plane down flying nose up as well.
I just had to land my falcon 120 with a malfunctioning flap last week and my landing strip is 90 meters long.
It wasn't pretty but the plane is intact. If you have a longer landing strip no flaps shoudn't be an issue.
#5083
Thoemse - no landing gear, and no 'strip' up on the cliffs.
Just bring her in for a belly-landing, and hope for the best.
Landing doesn't really bother me for where I fly Slope - you just come in and hope for the best.
Just hoping that it will actually 'glide' given enough breeze.
And yes - this is a Turbine thread - but it's also a Turbine-intended airframe.
I have no flaps - unless I work out how to make some and get them to work between the tail booms and the fuselage.
Might be something to consider.
Fly... or 'crash n trash', hey?
BJ
BJ
Woketman (07-27-2022)
#5085
My Feedback: (7)
Guys
These Falcons are simple machines, use servos like the HS5645s, these are digital, strong and fast enough for this jet, I use the same servos I’m my K140 powered jet, for retracts, use a set like the Robart 550s, the 630s are too much for it, smaller servos can be used on the rudders and elevator like the HS225, they are analogs, you can also get digitalis if you like them better.
If you guys want more details on the HS servos got to the Servo City servo chart, lots of info there.
https://www.servocity.com/servos/
Use flaps every time you land and maintain some power all the way to final, the flaps are there to slow it down so, don’t let it till it is over the runway ready to land, 400’ is more than enough runway to land, all airplanes can land with no flaps deployed, the trick is to manage the energy all the way down to the runway.
#5086
Retrofit an airbrake? I fly the smaller Bobcat 50 which have no flaps with a Wren 44 turbine & landing was tricky, you had to fly very shallow
approaches at low altitude to meet the end of the strip at a reasonable speed.
I fitted a perforated air brake approx. 100 mm square under the engine mounting platform which travels 90 deg.
Much easier now to balance thrust & rate of descent. Model flys off grass & has no wheel brakes.
#5087
Thanks Alasdair.
BJ
BJ
#5089
