Please help me on weathering a jet
This is a question for the scale jet builers.
I'm in the final stages of painting my jet. I weathered the yellow wings using a scale black wash. The fuselage is red. Is a scale black wash OK or does another color do a better job.
Thanks again
Peter
(RC-MAN)
Thanks again
Peter
(RC-MAN)
NJ
RE: Please help me on weathering a jet
The weathering on full scale aircraft does not change according to the fuse color so why should you utilize a different color on the red section. Keep it simple and it will look better.
Alan
Alan
My Feedback: (31)
RC_MAN, Dreamworksrc has some great tips in the tips section, there is a PDF file there that tells you how to weather a plane. Authored by Ralf Schneider. http://www.dreamworksrc.com/tips.htm
Don't be afraid to use gray hues to keep the effect more subtle. Also, adding a little burnt sienna / red hues on the bottom closely resemble dirt and dried hydraulic fluid. Of course, that depends if it's a carrier aircraft (less dirt) or a front line AF bird where dirt and grime on land based airports finds it's way into the mix.
Don't forget to look to the plastic model guys - painting and weathering are the holy grail to those guys and they know what they are doing. Do a few google searches and you are on your way. Here are a few links, you'll find a lot of reference material if you do a few searches.
http://www.aircraftresourcecenter.com/
http://www.hyperscale.com/
My Feedback: (84)
Subscribe to JET POWER magazine ( germany) you get a CD that contains a huge information bank on all jet model subject materials including painting and weathering
