Bandit ARF building question?
ID
Hey all,
After installing the tail pipe former and tail pipe, I'm not sure if the alignment is correct. The pipe is tight up against the top portion of the fuselage composite. Shouldn't there ba a gap? When I glued the former, I had to slide it along the inside of the fuselage until it touched the side walls, then I glued it there. The position ended up being under 4 inches from the end of the fuz. The manual says to glue it approx. 4" from the end.
I appreciate any help you can provide,
Steve Morris
Steve Morris
