Yellow Aircraft ARF F-16?
RE: Yellow Aircraft ARF F-16?
I have seen the Yellow F16 ARF finished in a USAF grey camo scheme... like the rest of their ARF's likely hard to get hold of as they seem to be only made available in limited low volume production runs.... The detail and finish of Yellow ARF's is truly as good as you will find for any ARF in fact more like a professionally finished model than any ARF's that I have seen, and Iam fussy too. I have one of their F-18 ARF's myself its very impressive
Get in touch with Shaun Evans (Yellow rep) and he will be able fill you in on details and as to availability...
hope this helps
Cheers-
hope this helps
Cheers-
My Feedback: (81)
gear is the $1000 BVM scale retracts, and its the model with the doors
this is it
http://www.rcuniverse.com/market/item.cfm?itemId=262199
this is it
Hi,
With respect, the F-16 in the picture is not a Yellow. What you are describing as flaps are actually flaperons, which both planes have. The tell-tale is the landing gear. Those gear are not Yellow. I can't say for sure, but they definitely look like BVM gear. The Yellow nose-gear is scale. The BVM one is not--it's just a Durostrut. If the plane in the pic is well-built, it's a steal at that price.
My Feedback: (57)
ORIGINAL: samo
I pretty sure the F-16 hanging up is a Yellow Aircraft F-16 and not a BVM F-16. The BVM F-16's don't have flaps.
Andrew
Andrew
$2300 is not that great of a deal. I've bought similar for a lot less RTF, both YA and BVM.
Offer him $1500 tops.
After all, it is a Dcuted Fan and it is a buyers market.
David
