Powerbox and Duralites
I have asked this question before in the battery forum, but got no reply so here it goes again.
Can we use duralite batteries on a regular powerbox evolution? I know there is a specific duralite powerbox as well....whats the difference in these two versions? Does it something to do with li-po and li-ions? Cut off Voltage? etc....
My Feedback: (51)
RE: Powerbox and Duralites
www.powerbox-systems.com will answer all of your questions.
The duralite one is simply a different model from PowerBox, its not made by Duralite.
Ragz
The only difference is the lable...fact
Duralite is the US brand name Emmerich allows
You can use either the voltage range is large enough
Dave Wilshere
Dave Wilshere
I believe the only difference between the Duralite and standard Powerbox is the calibration of the LEDs . On the Duralite Powerbox they are set up for Li-ion (Duralite) batteries. You can still use any type of battery.
This info was received from Duralite and Powerbox distributor.
Regards,
Davids Gladwin.
Regards,
Davids Gladwin.
I agree but that is what I was told . Perhaps it is the shape of the discharge curve. . Perhaps !
Regards, David Gladwin.
My Feedback: (51)
No other RC device on the planet distinguieshes between Li-po and Li-ion 7.4V, so the PB shouldnt as well.
Its not a discharge curve matter as well, sorry. different cells have different dischage curves, even within a specific brand or make, so no way.
You are right of course, a DC volt is a volt whatever the battery. However, PBs, were/are set up for Nicads/ NiMhs which do, of course, have a different voltage to lipos. I think that when Duralite started to market PBs their devices were set up with leds calibrated for lithium ions, like lipos, with a peak voltage of 8.4 whereas a 5 cell nicad will peak at around 7v. This, I am told by the Australian distributor, is the ONLY difference.
I believe the new PB is switchable between nicad-lipo so that the calibration of the LEDS is appropriate to the type of pack used.
They work very well particularly the unit with programmable servo outputs !
You do now !
The Powerbox 40/16 Evolution IS switcheable according to PowerBox on their web site. Please take a look at all the specs. including the use of jumpers for battery voltage assignement on the PowerBox web site. The Evolution is switcheable to the type of pack to be used .
Regards, DG.
Regards, DG.
Guys
The Evolution and Competition is switchable between Li-Po/Li-io and Ni cells with tiny dip switches.
This has been the case on the Evolution since day one and Competition for 6 months or so.
There is no LED calibration on Duralite, Emmerich told me they are the same...
Now on another note the RRS module is another PB brilliant stroke, you can now use your STD PB's with two Rx's from the big boys JR/Futaba etc It will also work without the PB so plug two Rx's into it and it will control the model with the strongest Rx.
regards
Dave Wilshere
regards
Dave Wilshere
My Feedback: (13)
ORIGINAL: Dave Wilshere
Can you comment on how the units 'decides' which is the best signal? It only seems to be conected to the receiver servo outputs...
I opened an RCU thread [link=http://www.rcuniverse.com/forum/m_6012522/tm.htm]here[/link]
thanks
