JR 10 programming question
I want to make the flap slider on the left side my smoke switch. Smoke is currently on AUX2. Flaps are currently on the three way switch on the left side. I want to bind AUX2 to the slider. I got it to work once but I can't remember what I did to get it to work. Right now when I bind AUX2 to the flaps the slider moves the flaps and turns the smoke pump on. I actually got it to work once but now it doesn't.
Andy
Andy
NJ
If you have disabled the flap lever in code 17 you can now perform a program mix of flap to aux2. the flap is no longer associated with the lever and in effect it is not a flap function even through you have flaps working with a three position switch.
follow this example.
1. Inhibit the Flap lever in Function Select (Code 17) if it is not
already inhibited.
2. Access an unused program mixer (51–55).
3. Select Channel 6 (AUX1/FLAP) as the Master and select
Channel 1 (throttle) as the Slave.
4. Touch PAGE two times and select Origin Mixing, telling the
mixer to sense the Flap lever.
5. Touch PAGE again to get to the first mixer screen.
6. Move the Flap lever all of the way down.
7. Touch STORE to store the offset—this sets the mix starting point
to the lever’s lowest position so that the idle can only be increased
and not accidentally decreased, which might kill the engine.
idle up to 15% of throttle travel.
9. Turn the receiver on and check to see if the throttle moves in
the correct direction—moving the Flap lever up should open
the throttle slightly. If it is reversed, touch TURN to reverse the
mix direction.
I hope this clears up what you are trying to do.
Alan
already inhibited.
mix direction.
Alan
