Need Help, Ram1ooo >
Need Help, Ram1ooo
Need Help, Ram1ooo
Old 03-09-2003 | 06:22 AM
Default Need Help, Ram1ooo
This engine pops real bad and does not finish the start,more times that if I to go to priming the engine it will start. It is judst a little wet start.......we can get to the fix on this......c'mon guys I beed your help. I am using green containers that the propane comes in, maybe I'm getting too rich of a mix of propane and it richens the system to much.............I'm grabbing at straws Any way to suggest a help. chime in........I'm alrady pass my 1/2 mark on heat cycles, and never been in the air. Seems as if the propane, and the fuel get it warm, it will stay a start..........I'm at a loss for words..........contact me hear,or on my [email protected], Bless our troops,and our President Bush, even if it was Gore or Clinton.......I still backem'.....just gotta get Bill away from those these expensive Cuban cigars and from underneath Monicas dress...........I have a feeling he missed some while he was getting "hummed to"in the "O" office......kida puts a new meaning on it huh?
Old 03-09-2003 | 07:31 AM
I assume this is an air start??? Is the propane/fuel new?
Chris
Old 03-09-2003 | 03:42 PM
Default Ram 1000
It sounds like your using the wrong propane if your using the green can? You should be using Power-max by Coleman.You can buy it at REI sporting goods or most sporting good stores. I`m fairly sure thats what everyones using on must engines Hope this helps. Ken
