Cermark F-18P Prop Jet first flights - impressions + pics
My Feedback: (41)
FL
RE: Cermark F-18P Prop Jet first flights - impressions + pics
i3dm;
I will order the Jett muffler and give it a shot, I agree the OS muffler is the weak link. Thanks for the feedback!
My Feedback: (41)
FL
Attention ALL Cermark F-18 owners!
My friend almost lost his F18 today apparently due to a loose stab aluminum control horn. After 4 or 5 flights one of the horns (that are only held in check by screw pressure on the stab rod) was either hit and moved position or simply loosened up on its own enough to cause pure havoc! The enclosed video shows the effect and a near fatal take off.
SOLUTION IS EASY:
YOU SHOULD DRILL A SMALL HOLE THROUGH THE ALUMINUM HORNS RIGHT INTO THE ALUMINUM RODS- THEN SECURE IT WITH A SET SCREW TO LOCK IN THE HORN AND ROD... THEY WILL NEVER SLIP AGAIN. THIS SHOULD BE MANDITORY FOR THIS PLANE.
Here is the link to the Youtube video:
http://www.youtube.com/watch?v=EjWPhqRwO6M
SOLUTION IS EASY:
CA
oooh....that was hairy.....I assume he made it down ok? hope so. I'll definately take care of that problem when I put mine together. It will be here tomorrow. Another good 'heads up',..thanks dotdigital.
George
George
#31
My Feedback: (41)
FL
TO ALL -
I am selling my Cermark F18! The plane is RTF and has been expertly built/balanced and trimmed out. THREE flights!
My Tamjet F16 just came in and I need to raise cash to pay for it! See my ad:
http://www.rcuniverse.com/market/item.cfm?itemId=318948
Pix enclosed here too...
#32
CA
wow,..thats a helluva deal there dotdigital. If I wasn't receiving mine today,..I'd buy it on the spot.
Talked to Dub today too, engine was shipped today too.
#35
hi can you tell me where can i buy the cermark f-18 pls?
cause i am having problems to register with the cermark webside.
thanks!
thanks!
#36
try www.cermark.net. That should get you to their website
#37
i allready did but i am having problems with the cermark website and i cannot buy one from cermark.
if someone knows where to buy it i will appreciate your help
thanks
thanks
