What do you think about JETLEGEND L39?
#501
RE: What do you think about JETLEGEND L39?
If you set your model up on trestles at the flying site you will find that the rear fuselage is not strong enough to take the weight of the model unless supported at the former!!
I have about .5mm of up aileron always. You can get a flick roll quite easily with that big rudder so it is safer like this. With the air brake mixed in with flap it slows down pretty well even with quite a high idle thrust .
Denny
Denny
#502
In case you lose, like me, during transportation to the field one or more of the bolts holding the wings (originals are 6-32 x 16mm) :
DUBRO #179 - Socket Head Bolt Sets With Lock Nuts - Size 6-32 x 1"
These bolts are longer and can be prevented to fall out the fuselage wing holders by using the secure nuts at the very ends.
The L-39 needs eight bolts, these Dubro sets are packed by 4 pcs each.
Hope this little hint helps.
Nicolas.
Nicolas.
#503
Has anyone had this problem. We are building 2 L39's, one went together just fine, but I am having problems with the elevators on the other one.
One side does not go in the stab far enough so the screws in the elevator reach the control rod. Had to grind off about 1/8" on the front of the elevator to get it to reach &
the screws still barely touch the control rod. Same problem on the other side plus they drilled the holes over too far & 1 screw dos'ent even touch the control rod. We tried
opening up the slot so we could then grind down the rod & make it fit. But the holes are so far left we went all the way through the inside of the aluminum piece thats glued into the elevator. I emailed jetlegend a couple times no answer, also sent email to cermark who I think is a dist. for them, no answer. Great customer service after the product is purchased!
#504
Are you sure you are using the right rod and not the one for the airbrake? I did have a slight problem with mine also, it did not give identical throws until it was modified.
Denny
Denny
#506
Hi Guys,
Just found this link, showing some nice details on a used L39 currently for sale.
Anybody got $390,000+ spare ??
copy the link into your web browser:
http://www.controller.com/listings/a...OS/1128305.htm
#507
ORIGINAL: TAILHOOK-RCU
Don't wait for the hassle of the factory eventually sending you new elevators. It isn't worth your valuable time, frustration and caused stress !
I didn't like the idea of eventually failing set screws or thread locker either and did the same, as Murphy is someone I never liked in this hobby.
Just my 2 cents...
Nicolas.
#509
Yes we had already decided to glue everything in as our next option, seeing you will never take them apart. But when you buy something & it is wrong the manufacturer should get back to you & do something.
As a person that has been selfemployed for 35 years, when a customer has a problem he is taken care of NOW!
I am all better now (LOL), time to move on.
#510
ORIGINAL: Jeremy_D
So whats the secret to getting the airbrake feet sitting properly?
Of course you have been grinding with a rotary dremel tool slots in the top side skin of the airbrake first where the feet are supposed to nestle in.
Check at least four times during slow curing process if they haven't moved.
For the fences/covers supplied in the kit : same system as with the flap rod covers : in tiny marks, it is visible on the fuselage where to put them just in front of the two air brake arms.
#512
Hi Nicolas
what system did you use to connect air pipes from wing to fuse have you any photos
thanks
Andreas
Hi John
sorry for not getting back to you my one is 109
thanks
Andreas
Hi John
#514
ORIGINAL: figueroa
Are the elevator hinge pockets pre drilled or did you drill them.
Thanks.
jef
Thanks.
jef
#515
ORIGINAL: ash 26
Hi Nicolas
Hi Nicolas
Robart #190 Quick Disconnects, the connector wing side glued to the wing (with ZAP-A-GOO).
Two for the IN-OUT of the retracts, the third one for the wheel brakes.
I used three different colours of air tubing.
(Sorry the pics attached were for another illustration purpose but you can see them well here)
#516
My Feedback: (22)
FL
ORIGINAL: SpiderJets
Predrilled, all around.
ORIGINAL: figueroa
Thanks.
jef
Thanks.
jef
#517
My Feedback: (47)
Just finished hinging (except flaps) and setting up airbrakes tonight...I did stiffen the fuse up a bit using ribbons of 1/4" uni CF up front and 1" wide strips of uni CF cloth in the rear, that helps tremendously on the bottom side (done for handling/carrying, rather than airworthiness concerns). I also need to file/grind the airbrake blades quite a bit as well as beveling the forward edges at a 45 degree angle. I also needed a 1/16" gap at the front edge of the AB blade 'fingers' (hinges?).
I did notice that the fuse bottom around the airbrakes flexes quite a bit, if I pushed in the fuse a little between the AB blades they would bind up...I added some CF cloth in the area between them from the former up to the fuse joint. A real pain to do after the rotation rod and related structure was glued in, but it solved that problem. I would suggest to anyone building this model to do the same before gluing in the AB assembly.
Very impressed with the quality of the mechanical components, the retracts and gear look great! They are big and heavy, going to use a BVM hi flow air valve to ensure they go up reliably.
Just wish they packed the heavy bits stored inside the fuse better, I had two chunks of ply formers broken out and a small hole in the fuse bottom from stuff moving around during shipping. No biggie, however.
barry
barry
#518
I just finished my airbrakes today as well!! Touched up the paint a bit with Tamiya Bright Red spray. I found the area stiffens up alot more when the fuel tank mount gets glued into place as well.
Tomorrows job is finishing the elevator!! then it's the rudder and then i'm ready for equipement install!
#519
I'm, just finish my wings and the speedbrake.
The wheel doors is already finish, I just need to put the Cylinder's
Look the front door
Look the front door
#520
I also have e-mailed jl twice and have not received a responce. I modified my rudder making a new opening.I;ll get some pic on line asap.Miss read the planes for the flap horn. I put it on the bottom. Changed it to the top wow what a differance.
#521
The Factory will be closed from 2nd Feb until 15th Feb for Chinese New Year. I got an email off Yang on the 1st in reply to an email sent.
#522
ORIGINAL: planegirl113
