What do you think about JETLEGEND L39?
#676
My Feedback: (47)
RE: What do you think about JETLEGEND L39?
ORIGINAL: yeahbaby
cut a hole in the door to clear the servo screw and then cover it with a blister.
you can call it an ECM sensor or cows tiits (as they are often referred to on the Hornoooot)
you know my philosophy, it's a ............for criist sake
Actually the entire width of the arm is a problem, not just the nut holding the ball link.
Barry
#678
As shown on Video link on post 664 no problem with servo arm on door.
Servo fitted to upper surface of mount, standard JR591 with standard arm.
Works perfectly.
All the best,
John C
Andreas,
Looks like a blow out again this weekend.[>:]
Works perfectly.
All the best,
John C
Andreas,
#679
My Feedback: (47)
Guess I'll need to get a low profile servo, because my setup is not any different than yours, John. (Nice job on the lights, BTW). I doubt my nose gear or bulkheads are any different from the other L39's out there, so it must be the deck height of the servo.
Here's a shot of the door closed on the servo and the servo install. It is a JR Sport ST126MG...need to go to the local hobby shop and sort through their stock of servos with a pair of calipers....
Barry
Barry
#680
Hi John
I got myself a few springs to experiment with[:-]
your lights lock very wellwhere did you get yours from?
like you said it looks like a right blow out again this week end[:@] ,hopefully we are going to get some good weather for the rest of the season
any one any experience with a JL T45?
Have a nice day
Andreas
Have a nice day
Andreas
#681
My Feedback: (21)
Hey F' that bro', it looks like a plane in the sky right? oh no[X(] I see a hole in the nose gear door!! harumph harumph harumph geez the nerve of that guy. burn 'em he's a witch!!! let's see if he floats!!!
heck poop can the nut on top and use a z-bend on the steering rod......then cut a hole in the door and some cowz tiitz
ORIGINAL: dbarrym
Yep....I think we ALL know your philosophy...kind of "Chuck Yeager meets Larry the Cable Guy"... you bozo!
Barry
Barry
#682
My Feedback: (24)
Barry... two options here....
1) loose the servo grommets, will most likely drop the servo enough to clear the door.
2) use an aluminum arm, thread the bolt in and cut flush with the top side of the arm (then thread lock!)
I'll have to go back and look at the pics I took of the one I built, don't remember this being an issue at all [sm=confused.gif]
T
T
#683
Barry,
Just put the servo on the other side of the mounting plate. Use a clevis it all lines up perfectly.
Regards,
John C
Andreas,
Light kit from Maplins with a few home mods.
Put it on earlier post.
All the best,
John c
Regards,
John C
Andreas,
All the best,
John c
#686
Hi All,
I try to find the best place to put my aerial.....
Can you post some pictures about your aerial fixation on the plane.
I have seen JetJohn have put just at the back of the canopy in the center of the fuselage, how do you have do it?
#689
Sandor
I have a new ECU for my Nexus but I need the Autostart parameters for this turbine, Can't get any replies from Simjet, are they still in business?
Denny
[email protected]
Denny
[email protected]
#691
Hi
has any one experience with running the wiring into the tail fin for the strobe light[:@]
Hi John
did you get any flights over the weekend I got out on Sunday it was very windy but I got one flight in with the Velox she Handel's
the wind well
all the best
Andreas
Hi John
the wind well
all the best
Andreas
#692
Hi Andreas,
Put three more flights on the Reaper, great fun.
It was pretty good wind wise, but the strip was ratther wet with some puddles. []
Put the buddy lead on & let a couple of friends have a go.
Great fun had by all, it is such a forgiving airframe.
Hope the strip drys out for this weekend.
All the best,
John C
All the best,
John C
#693
Hi John
like you said the Reaper is a real forgiving machine so you are getting rid of the rust for your maiden with the
Albatross I am afraid to say the weekend looks bad again we are planning on going out on Thursday evening for a fix
it looks good by the way what turbine are you using in the Reaper I had the Sim 2300 in it and it didnt have fly it well just a bit heavy for landing so it was alwaise a bit fast on finals[:-] I used it also to frighten some of the lads with there first Jet experiance
all the best
Andreas
all the best
Andreas
#694
Hi Andreas,
Mk1 Wren 13lbs thrust manual start turbine in the reaper. Once you get off the ground it soon winds up to some quite good speed.
It is so smooth & reliable you can have some really good fun with it. As you say, very forgiving, but what a floater.
Plus when it is half way through the flight & half way through its fuel load you start to get some good vertical performance.
I needed the fix to shake off the rust.
Just waiting for some decent weather.[]
All the best,
John C
All the best,
John C
#695
Did anyone have problems with the Tire hitting the inside of the fuse where it sits. When I retract it the tyre is hitting the inside of the fuse (where it curves near the intake) and not allowing the retract to lock. do you have to raise the gear on the mount at all? Is that what those metal parts in the LG set are for?
#696
Jeremy,
Yes, that is correct. I had the same observation when building mine. There are very thin rectangle alu corrective shims included in the kit to put under the retract units to get them in the correct angle, so they lock properly without friction at all when retracted, and having the struts still perpendicular when the bird stands on its legs. It is described earlier in this thread.
You will have to repeat this "trial and error" sequence a few times, in combination with the correct toe-in of the wheels. It is quite time consuming, but worth it to spend a lot of attention to it.
Nicolas.
Nicolas.
#698
The problem I'm now having is the strut won't allow the gear door to completely close. Did you have to take any material out of the door?
#700
Andreas,
I still have not been able to Maiden L39.
But have tried out a small Digital camera on my Reaper.
First try at our clubs open day Sat 12th April, result as link.
Will fit it into L39 cockpit.
All the best,
John C
http://uk.youtube.com/watch?v=91KrzOBYY_8
All the best,
John C
